Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
For additional help on the Samsung Gear VR with Controller, check out the device's troubleshooting page.
Background
The Samsung Gear VR with Controller (Model number: SM-R324NZAAXAR) was released to the public in April 2017 as a device used to create virtual reality out of a phone screen. By connecting any of the compatible Samsung phones (Galaxy S9, S9+, Note8, S8, S8+, S7, S7 edge, Note5, S6 edge+, S6, S6 edge, A8 Star, A8, and A8+), users can experience virtual reality.
The headset weighs .76 lbs and has a black, plastic exterior. It provides 360 degrees of viewing and allows for 2D and 3D content. The Samsung Gear VR connects to the phone via USB Type-C or Micro USB. A touchpad and back button are located on the right side of the headset.
The Gear VR also includes a small, lightweight controller that delivers a fast and easy way to interact with content. The controller has a wrist strap for secured grip and comfort.
Samsung has released six versions of the Samsung Gear VR headset. The SM-R324 is the second most recent model released. The newest model (SM-R325) has greater phone compatibility.
Identification
Technical Specifications
Headset
  • Dimensions: 207.1 x 120.7 x 98.6mm
  • Weight: 345g
  • Lens (Field of view (FOV)/Interpupilary distance (IPD)/Eye relief): 101˚/62mm (fixed)/10mm
  • Sensor: Gyro sensor/Proximity sensor
  • Phone Connection: USB Type-C & Micro USB
  • Compatible models: Galaxy Note9*, S9, S9+, Note8, S8, S8+, S7, S7 edge, Note5, S6 edge+, S6, S6 edge, A8 Star, A8, A8+ (Galaxy Note9 is only compatible with Gear VR model number SM-R325NZVC.)
  • Additional USB Port: USB Type-C for power connection, OTG USB memory, 3rd-party controller
Controller
  • Dimensions: 48.1 x 38.2 x 108.1mm
  • Weight: 64.3g (including battery and strap)
  • Sensor: Gyro sensor/Accelerometer/Magnetic (sampling Rate : 208Hz)
  • Indicator: 3-color LED * 1ea
  • Battery: AAA battery * 2ea (1000mAh, up to 40 days when used on average 2 hours a day)
  • Bluetooth: BT 4.2 BLE private profile
  • Compatible OS: Android Lollipop 5.0 or later
Source: Samsung Gear VR Specs
Additional Information
Wikipedia: Samsung Gear VR
Samsung's Official Page
Amazon Product Page
Samsung Gear VR Customer Review
Samsung SM-R324 使用手册
Samsung Gear VR SM-R324 User Manual
Author
with
Jake Criscione
587 Reputation
3 Guides authored
Cal Poly, Team S18-G3, White Winter 2019 Member of Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Members
84 Guides authored
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 84
All Time: 6,923
