Samsung Gear VR With Controller Focus Wheel Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
63
All Time:
685
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the focus wheel on your Samsung Gear VR is not working, use this guide to replace the focus wheel. To complete this replacement, you will need an iFixit opening tool, metal spudger, and Phillips #000 screwdriver head.
Tools
    1. Samsung Gear VR With Controller Focus Wheel  Replacement, Inner Mask: step 1, image 1 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement, Inner Mask: step 1, image 2 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement, Inner Mask: step 1, image 3 of 3
      • Push the switch on the right-hand side of the device to separate the cover from the main body.
      • Pull the cover away from the main device.
      Ask FixBot
    2. Samsung Gear VR With Controller Focus Wheel  Replacement: step 2, image 1 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 2, image 2 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 2, image 3 of 3
      • Remove the four corner screw covers with a metal spudger.
      • The screw covers fly off when removed, so make sure to keep track of them.
      Ask FixBot
    3. Samsung Gear VR With Controller Focus Wheel  Replacement: step 3, image 1 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 3, image 2 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 3, image 3 of 3
      • Use a metal spudger to remove the screw cover centered at the top.
      Ask FixBot
    4. Samsung Gear VR With Controller Focus Wheel  Replacement: step 4, image 1 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 4, image 2 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 4, image 3 of 3
      • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
      • Lift the front phone mount up and to the left.
      • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
      Ask FixBot
    5. Samsung Gear VR With Controller Focus Wheel  Replacement: step 5, image 1 of 2 Samsung Gear VR With Controller Focus Wheel  Replacement: step 5, image 2 of 2
      • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
      • Pull the plate away from the motherboard gently.
      Ask FixBot
    6. Samsung Gear VR With Controller Focus Wheel  Replacement: step 6, image 1 of 2 Samsung Gear VR With Controller Focus Wheel  Replacement: step 6, image 2 of 2
      • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
      • You can now completely remove the front phone mount from the headset.
      Ask FixBot
    7. Samsung Gear VR With Controller Focus Wheel  Replacement: step 7, image 1 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 7, image 2 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 7, image 3 of 3
      • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
      • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
      • The largest pop connector may require more effort to remove.
      • Make sure that nothing is connected to the motherboard before you pull it out.
      Ask FixBot
    8. Samsung Gear VR With Controller Focus Wheel  Replacement: step 8, image 1 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 8, image 2 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement: step 8, image 3 of 3
      • Remove the eight 5mm Phillips #000 screws on the inner mask.
      • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
      Ask FixBot
    1. Samsung Gear VR With Controller Focus Wheel  Replacement, Focus Wheel: step 9, image 1 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement, Focus Wheel: step 9, image 2 of 3 Samsung Gear VR With Controller Focus Wheel  Replacement, Focus Wheel: step 9, image 3 of 3
      • Remove the one 5mm Phillips #000 screw.
      • The screw for the focus wheel has a larger head than the rest of the screws.
      • Separate the focus wheel from the headset using your fingers.
      Ask FixBot
Harumi Hokari
243 Reputation
2 Guides authored
Cal Poly, Team S18-G3, White Winter 2019 Member of Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 63
All Time: 685
