Up to 20% off select tools
Samsung Gear VR With Controller Trackpad Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
53
All Time:
896
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If the trackpad on your Samsung Gear VR headset is not responding to touch, use this guide to replace the faulty trackpad. For this guide, you will need a Phillips #000 screwdriver, iFixit opening tool, and metal spudger.
    1. Samsung Gear VR With Controller Trackpad Replacement, Inner Mask: step 1, image 1 of 3 Samsung Gear VR With Controller Trackpad Replacement, Inner Mask: step 1, image 2 of 3 Samsung Gear VR With Controller Trackpad Replacement, Inner Mask: step 1, image 3 of 3
      • Push the switch on the right-hand side of the device to separate the cover from the main body.
      • Pull the cover away from the main device.
      Ask FixBot
    2. Samsung Gear VR With Controller Trackpad Replacement: step 2, image 1 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 2, image 2 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 2, image 3 of 3
      • Remove the four corner screw covers with a metal spudger.
      • The screw covers fly off when removed, so make sure to keep track of them.
      Ask FixBot
    3. Samsung Gear VR With Controller Trackpad Replacement: step 3, image 1 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 3, image 2 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 3, image 3 of 3
      • Use a metal spudger to remove the screw cover centered at the top.
      Ask FixBot
    4. Samsung Gear VR With Controller Trackpad Replacement: step 4, image 1 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 4, image 2 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 4, image 3 of 3
      • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
      • Lift the front phone mount up and to the left.
      • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
      Ask FixBot
    5. Samsung Gear VR With Controller Trackpad Replacement: step 5, image 1 of 2 Samsung Gear VR With Controller Trackpad Replacement: step 5, image 2 of 2
      • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
      • Pull the plate away from the motherboard gently.
      Ask FixBot
    6. Samsung Gear VR With Controller Trackpad Replacement: step 6, image 1 of 2 Samsung Gear VR With Controller Trackpad Replacement: step 6, image 2 of 2
      • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
      • You can now completely remove the front phone mount from the headset.
      Ask FixBot
    7. Samsung Gear VR With Controller Trackpad Replacement: step 7, image 1 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 7, image 2 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 7, image 3 of 3
      • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
      • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
      • The largest pop connector may require more effort to remove.
      • Make sure that nothing is connected to the motherboard before you pull it out.
      Ask FixBot
    8. Samsung Gear VR With Controller Trackpad Replacement: step 8, image 1 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 8, image 2 of 3 Samsung Gear VR With Controller Trackpad Replacement: step 8, image 3 of 3
      • Remove the eight 5mm Phillips #000 screws on the inner mask.
      • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
      Ask FixBot
    1. Samsung Gear VR With Controller Trackpad Replacement, Trackpad: step 9, image 1 of 3 Samsung Gear VR With Controller Trackpad Replacement, Trackpad: step 9, image 2 of 3 Samsung Gear VR With Controller Trackpad Replacement, Trackpad: step 9, image 3 of 3
      • Remove the one 5mm Phillips #000 screw to detach the trackpad from the headset.
      • Pry the trackpad loose from the headset using the spudger.
      Ask FixBot
Author
with
Jake Criscione
587 Reputation
3 Guides authored
Cal Poly, Team S18-G3, White Winter 2019 Member of Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 53
All Time: 896
