Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Saffun Wireless N64 Controller is a controller that is used for personal use and compatible with any device that supports USB and wireless connectivity . The SAFFUN Wireless N64 Controller introduced in October 20, 2019 its a 2.4 GHz as a comeback for the original N64 controller made by Nintendo on September 29, 1996.
The Controller weighs 10.23 ounces and a height of 6.01” (152.6 mm), width of 6.3” (160 mm) and a depth of 2.625” (66.7 mm). The controller comes in either gray or black color it comes with a USB stick to plug in to the console and that allows the controller to be connected to the desired console.
The Controller has 10 buttons, a directional pad, an analog stick, a USB stick and a Type-C charging port with a Type-C Charger. The controller is able to wirelessly connect to the console 33 feet (10 meters) away.
There is no recalls or failure models for this controller. The most common problems with this controller is the Analog Stick may start to drift after some time but this problem is easily fixable. and it may have problem charging. Other than the analog stick problems and the charging issues the controller has received great reviews on reliability, input, distance from console and build quality.
Identifications
The SAFFUN Wireless N64 Controller has a compact body with all the buttons clearly labeled. With the c buttons on the right, the analog stick on the middle and the Directional Pad on the left on the controller
Technical Specifications
  • Controller Size: 6.01 x 6.3 x 2.625 inches (HxWxD)
  • Weight: 10.23
  • GHz: 2.4
  • Battery Capacity: 500mA
  • Voltage: 3.7V
  • Usage Time: 10 Hours
Additional Information
Video on YouTube for Saffun N64 Controller
User Manual
Author
with
Ernesto Yanez
251 Reputation
0 Guides authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 84
All Time: 1,271
