Battery
2 Answers 1 Score |
Where is the microphone located |
1 Answer 0 Score |
Can the wireless be upgraded from WiFi 4 to WiFi 6? |
Documents
Tools
Troubleshooting
If you are having trouble with the Ring Spotlight Cam Battery, try referring to the troubleshooting page.
Background
The Ring Spotlight Cam Battery is a 1080p HD with a 140 degrees Field of View camera that is battery powered with two way audio with noise cancellations and spotlights that work efficiently in the dark and for security anywhere you may need them. It's motion sensors are adjustable which help the users adjust to their convenience for best results. The Ring Spotlight Cam Battery has 110-decibel alarm to help you scare off intruders. Its dimensions are 4.98 in. x 2.71 in. x 2.95 in. (125mm x 69mm x 75mm).
It was designed in California by Ring in 2017 and assembled in China.
Identification
Identified by model name: 2017 Ring Spotlight Cam Battery
Additional Information
Amazon reviews ring spotlight cam Battery
Help installing your ring surveillance
