Ring Spotlight Cam Battery The Mounting Bracket Replacement
  1. Ring Spotlight Cam Battery The Mounting Bracket  Replacement, The Mounting Bracket: step 1, image 1 of 1
    • Place Mounting Bracket with lower elevation facing towards you.
    Ask FixBot
  2. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the single bracket screw.
    Ask FixBot
  3. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: step 3, image 1 of 1
    • Hold two corners from the middle of bracket and stretch outward.
    Ask FixBot
  4. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: step 4, image 1 of 1
    • Slide bracket upwards.
    Ask FixBot
1 Guide Comment
I have lost the single bracket screw. Where can I get a replacement?
Rick Burgess - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 31
All Time: 3,273
