Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
This troubleshooting page will help you diagnose problems with the Ring Spotlight Cam Battery
Motion Sensors Are Failing
Motion and lights control is not activated.
Motion Settings are Turned Off
Tap on the Motion Setting tile for access to the motion control and lights controls.
Motion Zone Controls are not adjusted
Select motion zones on the app and customize the areas to trigger the camera to turn on when motion is detected. Simply tap on the diagram to turn on the motion zone on or off.
Video Delays Are Extensive
The ring spotlight cam is offline or the location is not set-up properly.
Wi-Fi Signals are not extending
Bring the Spotlight Cam near a router and open the Ring app. Press the Live View button on the app or trigger a motion event to view live video. If the video quality of the camera is good near your router, you need to extend your Wi-Fi signal.
Improper Height Installation
It’s important when selecting a location. Make sure to place the Ring Spotlight at an optimal height of nine feet. This will put the motion sensor in a perfect position to detect human-size objects up to 30 feet.
Weak Wireless Connection
The ring spotlight is offline.
Internet Router Needs Resetting
Check if there is an internet connection problem, by opening the “Ring App” and select your Ring device and then select “Ring Health”, if your Ring device is offline it will say “Offline” under the “Network header”. There can be a power surge, a wire in your router setup temporarily comes loose, or you temporarily lose power which will affect your internet router. The next step would be to check if all of your wires are plugged in and the front of the routers lights are all green. Check if another device is having trouble connecting to the Wi-Fi connection. Try unplugging your router for 30 seconds then connecting it again. Remove the internal battery of the device then insert it again and check if the device has a Wi-Fi connection.
Charge Removable Battery
If Wi-Fi connection is not the case the removable battery needs to be charged.
Ring Spotlight Cam is Not Turning On
The batteries are not powering the cam device.
Recharge the Battery
Take the battery and plug it into a power source so the battery can charge for a couple of hours before installation. When the battery is fully charged the small light on top will turn green and will be ready for installation.
Properly Insert the Battery
Insert the the battery into your ring spotlight cam until you can hear it click into place.
LED Lights Do Not Turn On
LED light control.
Light Brightness is Not Properly Set
Tap on the Light Settings tile for access to the motion zone Light Brightness control. Use this control to adjust the brightness of your spotlights when they activate.
Light Settings are Turned Off
The lights on the Spotlight Cam will only turn on when it is dark outside and their is motion. If the lights aren't turning on at night then you can adjust the motion sensitivity. If you do not want your lights to turn on at night you can also, manually control your spotlight through the lights control.
66 Comments
Camera is not charging up with the solor panel.
One of the lights does not come on and I checked
The solor panel and it is good.
kknop - Reply Share
Hello did you ever figure yours out? I have a solar panel to and not charging the battery. Battery won’t even hold charge when I put it in
hcobabii3x - Reply Share
Battery has charged for 5 hours and still no green light is coming on. I need to know if battery needs to be replaced because it’s less than a year old.
Jon Mcdermott - Reply Share
We have the same issue too! We are testing it overnight to see if green light appears
Jane Brown - Reply Share
I ended up calling RING. My camera was still within warranty so they sent me a replacement camera
kbsnowlov - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 66
All Time: 37,334
