Ring Spotlight Cam Battery Motion Detector Replacement
  1. Ring Spotlight Cam Battery Motion Detector Replacement, Motion Detector: step 1, image 1 of 1
    • Rotate the camera so the mounting bracket is facing you.
    • Turn the camera so the mounting bracket is at the bottom.
    Ask FixBot
  2. Ring Spotlight Cam Battery Motion Detector Replacement: step 2, image 1 of 1
    • Press the top button and slide your thumb upward to open the camera.
    Ask FixBot
  3. Ring Spotlight Cam Battery Motion Detector Replacement: step 3, image 1 of 1
    • Remove the batteries in the camera before proceeding.
    • Remove the two screws located in the middle of the cover with a Phillips #1 screwdriver.
    Ask FixBot
  4. Ring Spotlight Cam Battery Motion Detector Replacement: step 4, image 1 of 1
    • Remove the middle component.
    Ask FixBot
  5. Ring Spotlight Cam Battery Motion Detector Replacement: step 5, image 1 of 1
    • Remove the sticker on the cover.
    • Remove the 10 screws located around the edge of the cover.
    Ask FixBot
  6. Ring Spotlight Cam Battery Motion Detector Replacement: step 6, image 1 of 1
    • Carefully close the cover.
    Ask FixBot
  7. Ring Spotlight Cam Battery Motion Detector Replacement: step 7, image 1 of 1
    • Remove the cover and replace the LED light.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 90
All Time: 2,980
