Ring Spotlight Cam Battery Lights Replacement
  1. Ring Spotlight Cam Battery Lights Replacement, Lights: step 1, image 1 of 1
    • Remove the top plastic pad by peeling it off with a metal spudger.
    Ask FixBot
  2. Ring Spotlight Cam Battery Lights Replacement: step 2, image 1 of 2 Ring Spotlight Cam Battery Lights Replacement: step 2, image 2 of 2
    • Remove the 7 PH00 screws around the four corners with PH00 of the lid.
    Ask FixBot
  3. Ring Spotlight Cam Battery Lights Replacement: step 3, image 1 of 1
    • Use the metal spudger set to break the glue lining and the motion sensor will pop out.
    Ask FixBot
6 other people completed this guide.
5 Guide Comments
this showed nothing about replacing the light bulb
Martha “purplemarty” Ewell - Reply Share
This is not a complete how to. The directions stop in the middle and don't show the replacement of the LEDs. Also no parts link for the replacement LED strips
Matt Newman - Reply Share
very short and sweet i did it
john zhou - Reply Share
Wait, what? This is incomplete. The directions don't show the replacement of the LED lights.
Richard Millet - Reply Share
Where is the step that shows how to remove the existing light assemblies? Where do you buy replacement LEDs?
How do you install NEW light assemblies?
Guide ends with popping off the motion sensor. Ok, but HOW DO I REPLACE THE LED LIGHTS?
This guide is worthless!
Patrick Santucci - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 71
All Time: 6,923
