Back Cover
5 Answers 4 Score |
Can you replace Nook st/gl screen with nook st without gl? |
2 Answers 1 Score |
Nook glowlight awake button broke |
1 Answer 0 Score |
Nook Glowlight not working |
1 Answer 4 Score |
USB port came loose |
Documents
Tools
Repairability Score
Background
The Nook Simple Touch with Glowlight is an easy-to-use digital reader. On your Nook, you can read books, papers, magazines, store and read files, and more. The Glowlight feature delivers an innovative lighting solution that allows users to control the amount of light illuminating their screen in low light settings. It also has a lightweight and portable design, along with long-lasting battery life. With Glowlight enabled, a Nook is designed to last over a month on one charge.
The Nook Simple Touch with Glowlight is similar to the original Nook Simple Touch, with the addition of the Glowlight for better lighting control, and a built-in anti-glare screen protector. The addition of the Glowlight also causes the expected battery life of the device to decrease from 2 months to 1 month when enabled.
Identification
The Nook Simple Touch with Glowlight has most of the same specs as the Nook Simple Touch, with a Glowlight light added to help with late-night reading and a grey frame around the edge of the case. Furthermore, accessing the “About Your NOOK” page of the device info section of the settings menu should provide you with the model number BRNV350.
Tech Specs
OS: Android 2.1 with B&N Custom Skin
Model: BNRV350
Display: 6-inch eInk touchscreen with GlowLight, 600×800 resolution, 16-level grayscale
Battery: 1 month with GlowLight on; two months off
Processor: 800 MHz TI OMAP 3621
RAM: 256 MB
Internal Storage: 2GB (1,000 books), expandable with microSD
Network: Wi-Fi only
Height: 6.5’’(170 mm)
Width: 5.0’’(130mm)
Depth: .47’’(12mm
Weight: 6.95 oz. (197 g)Troubleshooting
Additional Links
Barnes & Noble NOOK User Guide
Barnes & Noble NOOK Simple Touch Fact Sheet
Barnes & Noble: Nook Simple Touch with GlowLight
