Nook Simple Touch with GlowLight Charging Port Replacement
  1. Nook Simple Touch with GlowLight Charging Port Replacement, Power Button: step 1, image 1 of 1
    • Place the Nook with the screen facing down.
    Ask FixBot
  2. Nook Simple Touch with GlowLight Charging Port Replacement: step 2, image 1 of 1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
    Ask FixBot
  3. Nook Simple Touch with GlowLight Charging Port Replacement: step 3, image 1 of 1
    • Using your fingers, gently remove the power button.
    Ask FixBot
  4. Nook Simple Touch with GlowLight Charging Port Replacement, Back Cover: step 4, image 1 of 1
    • Remove the single screw using a T4 Torx screwdriver.
    Ask FixBot
  5. Nook Simple Touch with GlowLight Charging Port Replacement: step 5, image 1 of 1
    • Slide the back cover down towards you in the direction of the charging port.
    Ask FixBot
  6. Nook Simple Touch with GlowLight Charging Port Replacement, Battery: step 6, image 1 of 2 Nook Simple Touch with GlowLight Charging Port Replacement, Battery: step 6, image 2 of 2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
    Ask FixBot
  7. Nook Simple Touch with GlowLight Charging Port Replacement, Motherboard: step 7, image 1 of 1
    • Remove eleven screws from the motherboard using the T4 screwdriver.
    Ask FixBot
  8. Nook Simple Touch with GlowLight Charging Port Replacement: step 8, image 1 of 3 Nook Simple Touch with GlowLight Charging Port Replacement: step 8, image 2 of 3 Nook Simple Touch with GlowLight Charging Port Replacement: step 8, image 3 of 3
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
    Ask FixBot
  9. Nook Simple Touch with GlowLight Charging Port Replacement, Charging Port: step 9, image 1 of 1
    • Flip the motherboard over and locate the charging port.
    Ask FixBot
  10. Nook Simple Touch with GlowLight Charging Port Replacement: step 10, image 1 of 1
    • Using a soldering iron, disconnect the charging port from the motherboard.
    • Use the soldering iron to attach the new charging port to the motherboard.
    • Be careful with the soldering iron - it is very hot and can damage your hands or the device.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 35
All Time: 517
