Nook Simple Touch with GlowLight Battery Replacement
    1. Nook Simple Touch with GlowLight Battery Replacement, Power Button: step 1, image 1 of 1
      • Place the Nook with the screen facing down.
      Ask FixBot
    2. Nook Simple Touch with GlowLight Battery Replacement: step 2, image 1 of 1
      • Wedge the opening tool between the power button and the upper edge of the device.
      • Push the opening tool down to pry the power button up.
      Ask FixBot
    3. Nook Simple Touch with GlowLight Battery Replacement: step 3, image 1 of 1
      • Using your fingers, gently remove the power button.
      Ask FixBot
    1. Nook Simple Touch with GlowLight Battery Replacement, Back Cover: step 4, image 1 of 1
      • Remove the single screw using a T4 Torx screwdriver.
      Ask FixBot
    2. Nook Simple Touch with GlowLight Battery Replacement: step 5, image 1 of 1
      • Slide the back cover down towards you in the direction of the charging port.
      Ask FixBot
    1. Nook Simple Touch with GlowLight Battery Replacement, Battery: step 6, image 1 of 2 Nook Simple Touch with GlowLight Battery Replacement, Battery: step 6, image 2 of 2
      • Detach the white cable connector from the motherboard.
      • Remove the battery from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 45
All Time: 1,493
