Released May 1, 2012. The first backlit eReader tablet emits a soft backlight for improved night reading. The device is simple to open up, but the components are all connected.
Nook Glowlight not working
Hi. I dropped my Nook with Glowlight and the case came loose. I followed the tear down instructions and took the Nook apart and put it back together sealing the case. It works fine except I lost the Glowlight feature in the process. I can't turn the Glowlight on at all. Any ideas or suggestions? Thanks.
Add a comment
1 Answer
Chosen Solution
I fixed it. There is a tiny ribbon cable in the upper left corner of the motherboard that I dislodged when I put the case back together. Plugged in the cable, closed the case and all is glowing as it should.
Add a comment
Add your answer
MarkT will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 877
