Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Mayflash Arcade Stick F300 is an arcade-style joystick. It supports compatibility with over 10 consoles, including the Nintendo Switch, PlayStation 4, PlayStation 3, Xbox Series X/S, Xbox One, Xbox 360, PC (Windows and macOS), Steam Deck, Raspberry Pi, Android devices, NEOGEO mini, NEOGEO Arcade Stick PRO, SEGA MEGA DRIVE, GENISI Mini, and Astro City Mini.
Users can customize the stick with Sanwa Denshi buttons and joysticks. It operates in XINPUT and DINPUT modes when connected to a PC, allowing for flexible usage across different devices. The arcade stick includes turbo functions for adjustable speeds and offers interchangeable D-Pad and X/Y Analog Axis modes to enhance gameplay control.
Identification
This model is easily identified by the model name Arcade Stick F300 in the bottom left corner and the Mayflash brand logo in the upper right corner of the device.
Technical Specifications
  • System Compatibility
  • Nintendo Switch
  • PC Windows
  • PS4, PS3
  • Android
  • Xbox Series X/S
  • Xbox One, Xbox 360
  • NeoGeo mini
  • SEGA MEGA DRIVE
  • SEGA GENESIS mini
  • Sega Astro City mini
  • Steam Deck
Special Features
  • Dynamic Button Layout
  • Perfect for customization
  • Ultimate Software
  • D-pad and X/Y Analog Axis switch
  • Turbo Functionality
Inputs
  • XINPUT/NS, Game Console and DINPUT/PS3
  • XINPUT/NS: Supports PC Xinput and Switch
  • GAME CONSOLE: Compatible with PS4, Xbox One, Xbox 360.
  • DINPUT/PS3: Supports PC Dinput and PS3
X/Y and Dpad
  • If the switch is set to the "X/Y, the stick works as the "Left Joystick.
  • If setting the switch to "DPAD, the stick works as "POV.
TURBO-1 and TURBO-2
  • TURBO-1: The Turbo speed is 15 times/ second.
  • TURBO-2: The Turbo speed is 25 times/second.
Connectivity
  • USB
  •  Please make sure you plug the wired controller to the arcade stick when you use it on PS4, Xbox One, and Xbox 360.
MAYFLASH JOYSTICK
  • Compatible with Sanwa Stick Model TP-8YT
MAYFLASH BUTTONS
  •  8 blue buttons are compatible with Sanwa Buttons Model OBSF-30
  • 1 black button is compatible with Sanwa Button Model OBSF-24
USB PORT
  • The USB port is used to plug the wired controllers.
Includes
  • MAYFLASH Arcade Stick F300
  • One meter USB Cable
  • One USB Type-C Cable
  • Octagonal Gate
  • Manual
Dimensions and Weight
  • 30.2x23.6x11.3 cm
  • 1591g
Additional Information
Author
with
Jess Anderson
342 Reputation
3 Guides authored
Past 24 Hours: 5
Past 7 Days: 43
Past 30 Days: 145
All Time: 1,801
