Mayflash Arcade Stick F300 Joystick Replacement
  1. Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: step 1, image 1 of 3 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: step 1, image 2 of 3 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: step 1, image 3 of 3
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
    Ask FixBot
  2. Mayflash Arcade Stick F300 Joystick Replacement, Joystick: step 2, image 1 of 2 Mayflash Arcade Stick F300 Joystick Replacement, Joystick: step 2, image 2 of 2
    • Detach the micro switch cables connected to the PCB (printed circuit board).
    Ask FixBot
  3. Mayflash Arcade Stick F300 Joystick Replacement: step 3, image 1 of 3 Mayflash Arcade Stick F300 Joystick Replacement: step 3, image 2 of 3 Mayflash Arcade Stick F300 Joystick Replacement: step 3, image 3 of 3
    • Use a flathead screwdriver to hold the bottom screw of the joystick lever in place.
    • Flip the device over.
    • Grab the ball top of the joystick and twist while the screwdriver prevents the screw from turning.
    • Once the ball top is removed, slide off the plastic tube and plate from the joystick.
    Ask FixBot
  4. Mayflash Arcade Stick F300 Joystick Replacement: step 4, image 1 of 3 Mayflash Arcade Stick F300 Joystick Replacement: step 4, image 2 of 3 Mayflash Arcade Stick F300 Joystick Replacement: step 4, image 3 of 3
    • Flip the device over again, exposing the inside.
    • Use a Phillips #1 screwdriver to remove the four screws holding down the joystick lever.
    • Slide the joystick out of the outer plastic casing.
    Ask FixBot
Jess Anderson
342 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 68
All Time: 898
