Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓If the microswitches in your Mayflash Arcade Stick F300 are broken or damaged, use this guide to replace them.
Each direction (up, down, left, right) in the joystick corresponds to a microswitch. When the joystick is moved, it physically presses the associated microswitch, closing its circuit and signaling to the console the direction.
Because each microswitch corresponds to a different direction, make sure you are replacing the correct microswitch, and be careful to keep track of the wires to ensure everything is reconnected properly.
Flip the controller upside down so that the metal panel is facing you.
Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
Once all screws are removed, lift off the panel.
Remove the four 9 mm truss head screws fastening the clear plastic square joystick gate to the casing underneath using a Phillips #1 screwdriver.
