Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The HP Pavilion 15-cs3079nr is a mid-range laptop released by HP as part of the Pavilion
15-cs series. It features a 15.6-inch touchscreen display and is built on hardware intended for general productivity and multimedia use.
The chassis includes several I/O ports for connectivity:
  • Two USB 3.1 Gen 1 Type-A ports (SuperSpeed)
  • One USB 3.1 Gen 1 Type-C port
  • One HDMI 1.4b port for external displays
  • An RJ-45 Ethernet port and a headphone/microphone combo jack
Internal components include a built-in HD webcam and integrated dual-array digital microphones. For wireless communication, the device utilizes an 802.11b/g/n/ac Wi-Fi adapter and Bluetooth 5.0.
Identification
The HP Pavilion 15-cs3079nr is a "clamshell" style laptop featuring a silver aluminum cover and a keyboard frame with a matte finish.
Physical Characteristics
  • Dimensions: 14.24 x 9.67 x 0.70 inches (36.16 x 24.56 x 1.79 cm).
  • Weight: Approximately 4.25 lbs (1.92 kg).
  • Display: 15.6-inch diagonal Full HD (1920 x 1080) micro-edge WLED-backlit touchscreen.
  • Keyboard: Full-size keyboard with a dedicated keypad.
Locating Model Information
To distinguish this model from other Pavilion 15-cs units, users can locate the specific model number (15-cs3079nr) in the following ways:
  1. Bottom Case: Look for the small-print regulatory label laser-etched or printed on the bottom of the laptop chassis.
  2. System Information: Press [Fn + Esc] on the keyboard to open the HP System Information window, which displays the product name and serial number.
  3. Battery Compartment: While this model features an internal battery, the product ID is also listed on the regulatory sticker located on the internal side of the bottom panel.
Technical Specifications
Processor: Intel Core i5-1035G1 (1.0 GHz base, up to 3.6 GHz, 6 MB cache, 4 cores)
Memory: 8 GB DDR4-2666 SDRAM (1 x 8 GB)
Storage: 256 GB PCIe NVMe M.2 SSD
Display: 15.6’ diagonal FHD IPS BrightView micro-edge WLED-backlit touch screen
(1920 x 1080)
Graphics: Intel UHD Graphics
Battery: Lithium Ion
Networking: Realtek 802.11a/b/g/n/ac (2 x 2) Wi-Fi and Bluetooth 5 combo
Ports: 2 x USB-A 3.1 Gen 1, 1 x USB 3.1 Type-C, 1 x HMDI, 1 x RJ-45, 1 x Headphone/microphone combo
Operating System: Windows 10 Home 64-bit or Windows 11 Home
Additional Features: Front-facing HD camera, dual speakers with audio boost, and numeric keypad
Additional Information
HP's device support page.
3rd party device overview, specs, and document breakdown.
Device disassembly video guide.
Author
with
Nicolas Soto
751 Reputation
6 Guides authored
Past 24 Hours: 12
Past 7 Days: 16
Past 30 Days: 50
All Time: 275
