HP Pavilion 15-cs3079nr Lower Case Replacement
    1. HP Pavilion 15-cs3079nr Lower Case Replacement, Lower Case: step 1, image 1 of 3 HP Pavilion 15-cs3079nr Lower Case Replacement, Lower Case: step 1, image 2 of 3 HP Pavilion 15-cs3079nr Lower Case Replacement, Lower Case: step 1, image 3 of 3
      • Power the device off before disassembly.
      • Close the device and flip it so the bottom panel faces up.
      Ask FixBot
    2. HP Pavilion 15-cs3079nr Lower Case Replacement: step 2, image 1 of 2 HP Pavilion 15-cs3079nr Lower Case Replacement: step 2, image 2 of 2
      • Remove the two silicon feet near the hinges with a spudger.
      • If you intend to reuse the feet, heat them with a hairdryer prior to removal and take care not to bend, warp, or stretch them.
      Ask FixBot
    3. HP Pavilion 15-cs3079nr Lower Case Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the three 7 mm screws from the recesses.
      Ask FixBot
    4. HP Pavilion 15-cs3079nr Lower Case Replacement: step 4, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the three silver 5 mm case screws from the front of the device.
      Ask FixBot
    5. HP Pavilion 15-cs3079nr Lower Case Replacement: step 5, image 1 of 3 HP Pavilion 15-cs3079nr Lower Case Replacement: step 5, image 2 of 3 HP Pavilion 15-cs3079nr Lower Case Replacement: step 5, image 3 of 3
      • Place the suction handle on the case.
      • Insert an opening pick between the case sections and work around the perimeter of the device to separate the lower case from the chassis.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 32
All Time: 74
