Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Out of Storage
The device is unable to install new apps or store music and pictures.
Lack of Internal Storage
This device does not have much room for additional applications, games, music, pictures, or videos. If you need to install an app but you do not have sufficient storage capacity, you can migrate your pictures and videos to a larger MicroSD card. If there is still not enough room, then we suggest using the internet browser on your phone in place of the application you are installing.
Frozen Screen
The screen and buttons are unresponsive.
Phone Needs to be Restarted
If your device fails to respond to both touch and button commands, you can force restart your phone by simply removing the hard shell on the back to reveal the battery. Then, remove the battery and put it back in again. Put the hard shell back on your device. This will force restart your phone.
Faulty LCD Screen
If force restarting your phone did not work to solve an unresponsive screen, you may have a faulty LCD screen. This could be because of a cracked screen or internal damage. You may consider replacing your screen.
Device Fails to Hold Charge
The battery dies quickly.
Too Many Running Apps
Press and hold the menu button in the bottom right corner of your device. Swipe left or right to close the selected application. Doing this will help with extending your battery life.
Outdated Applications
Use the Google Play Store to update your apps. Running the latest version of an application should conserve battery life.
Faulty Battery
If your battery life has not improved after these methods, then you may have a faulty battery. You may consider replacing your battery.
Rear Camera is Not Functioning
Camera remains dark when opened.
SD Card Malfunction
Try removing and reinserting the SD card. Be sure the SD card is inserted fully and positioned correctly. A mispositioned SD card may prevent the camera from correct operation.
Faulty Rear Camera
If the rear camera still isn't loading, try holding down the power button for 10-15 seconds. If phone powers back on and issue remains unsolved, check to be sure the software has the latest update. If camera remains unresponsive, you may consider replacement.
Device Fails to Turn On
The phone remains unresponsive when you try to power it on.
Faulty Power Adapter
Check to make sure you are using a working charger cable by plugging in another device, if possible. If no other device is available, try charging phone on a car charger. If the phone powers on using car charger but not wall outlet, you may need to purchase a new charger cable.
Battery Corrosion
If the power adapter doesn't seem to be the issue, remove battery and check for residue that may be interfering with connection. If your battery is corroded, you may consider replacing it.
Motherboard Malfunction
If the phone still remains unresponsive, you may have a malfunctioning motherboard. You may consider replacing the motherboard.
Tayler McCleese
246 Reputation
2 Guides authored
Ohio State, Team S1-G4, Whitney Fall 2018 Member of Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 30
All Time: 522
