Up to 20% off select tools
ZTE Compel Motherboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
70
All Time:
818
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The ZTE Compel features a removable and replaceable motherboard. You may need to replace the motherboard if your phone is no longer responsive and there are no signs of power. Please take all necessary precautions, such as protective gloves and eyewear, if dealing with battery corrosion.
    1. ZTE Compel Motherboard Replacement, Battery: step 1, image 1 of 1
      • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
      Ask FixBot
    2. ZTE Compel Motherboard Replacement: step 2, image 1 of 1
      • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
      Ask FixBot
    3. ZTE Compel Motherboard Replacement: step 3, image 1 of 1
      • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
      • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
      Ask FixBot
    1. ZTE Compel Motherboard Replacement, Camera: step 4, image 1 of 2 ZTE Compel Motherboard Replacement, Camera: step 4, image 2 of 2
      • Remove the 9 screws that measure 4 mm Phillips #000.
      • Use your iFixit Magnetic Project Mat, or any magnetic surface, to hold your removed screws while working on your ZTE Compel.
      Ask FixBot
    2. ZTE Compel Motherboard Replacement: step 5, image 1 of 3 ZTE Compel Motherboard Replacement: step 5, image 2 of 3 ZTE Compel Motherboard Replacement: step 5, image 3 of 3
      • Notice the crease in the shiny black plastic. Insert the flat end of your spudger here, about 3mm above the volume buttons, and work your spudger around the circumference of the phone until the front and back are separated.
      Ask FixBot
    3. ZTE Compel Motherboard Replacement: step 6, image 1 of 2 ZTE Compel Motherboard Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the camera by placing your tweezers on the gold piece attached to camera and lift up, disconnecting from the motherboard.
      • Grip the camera with your tweezers and lift up to remove the camera.
      • May need to use light force to remove camera due to the adhesive on the motherboard.
      Ask FixBot
    1. ZTE Compel Motherboard Replacement, Motherboard: step 7, image 1 of 2 ZTE Compel Motherboard Replacement, Motherboard: step 7, image 2 of 2
      Buy
      • Use your tweezers to remove the black electrical tape covering connectors to the motherboard.
      • Use your tweezers to flip the brown clip up, and pull the ribbon connectors out of the connections.
      Ask FixBot
    2. ZTE Compel Motherboard Replacement: step 8, image 1 of 1
      • Use your tweezers to disconnect the final ribbon connector underneath the motherboard at the top of the phone. The motherboard can now be separated from the LCD Screen.
      Ask FixBot
Author
with
Kidron Stamper
327 Reputation
3 Guides authored
Ohio State, Team S1-G4, Whitney Fall 2018 Member of Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 70
All Time: 818
