Up to 20% off select tools
ZTE Compel Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
8
Past 30 Days:
57
All Time:
685
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The ZTE Compel features a rechargeable lithium ion battery. You may need to replace the battery if it no longer holds a charge, if the battery is corroded, or if you are simply force restarting your phone. Please take all necessary precautions, such as protective gloves and eyewear if dealing with battery corrosion.
    1. ZTE Compel Battery Replacement, Battery: step 1, image 1 of 1
      • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
      Ask FixBot
    2. ZTE Compel Battery Replacement: step 2, image 1 of 1
      • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
      Ask FixBot
    3. ZTE Compel Battery Replacement: step 3, image 1 of 1
      • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
      • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
      Ask FixBot
Author
with
Kidron Stamper
327 Reputation
3 Guides authored
Ohio State, Team S1-G4, Whitney Fall 2018 Member of Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 57
All Time: 685
