Up to 20% off select tools
ZTE Compel Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
59
All Time:
689
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This replacement guide will provide you with the necessary instructions on how to replace the rear camera. You may need to replace the camera if you have tried removing and reinserting the SD card, and/or turning the phone on and off again and the camera still remains unresponsive.
    1. ZTE Compel Camera Replacement, Battery: step 1, image 1 of 1
      • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
      Ask FixBot
    2. ZTE Compel Camera Replacement: step 2, image 1 of 1
      • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
      Ask FixBot
    3. ZTE Compel Camera Replacement: step 3, image 1 of 1
      • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
      • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
      Ask FixBot
    1. ZTE Compel Camera Replacement, Camera: step 4, image 1 of 2 ZTE Compel Camera Replacement, Camera: step 4, image 2 of 2
      • Remove the 9 screws that measure 4 mm Phillips #000.
      • Use your iFixit Magnetic Project Mat, or any magnetic surface, to hold your removed screws while working on your ZTE Compel.
      Ask FixBot
    2. ZTE Compel Camera Replacement: step 5, image 1 of 3 ZTE Compel Camera Replacement: step 5, image 2 of 3 ZTE Compel Camera Replacement: step 5, image 3 of 3
      • Notice the crease in the shiny black plastic. Insert the flat end of your spudger here, about 3mm above the volume buttons, and work your spudger around the circumference of the phone until the front and back are separated.
      Ask FixBot
    3. ZTE Compel Camera Replacement: step 6, image 1 of 2 ZTE Compel Camera Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the camera by placing your tweezers on the gold piece attached to camera and lift up, disconnecting from the motherboard.
      • Grip the camera with your tweezers and lift up to remove the camera.
      • May need to use light force to remove camera due to the adhesive on the motherboard.
      Ask FixBot
Author
with
Tayler McCleese
246 Reputation
2 Guides authored
Ohio State, Team S1-G4, Whitney Fall 2018 Member of Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 59
All Time: 689
