Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Specifications
Announce Date: June 25, 2013
Weight: 7.5 ounces ~ 212 g
Dimensions: 7.06 x 3.63 x 0.26 in
Capacity: 16 GB
RAM: 2 GB (Snapdragon 800)
MicroSD slot
Micro- SIM
  • Screen
  • 6.4 inch
  • Shatter-proof glass
  • 1920x1080 resolution (Black, white, purple)
    • 10 finger multitouch
    • Triluminos display
  • OS
    • Android v4.2/v5.1
    • X-reality engine
  • Cameras
    • 2 megapixel front camera with 1080p at 30 fps
    • 8 megapixel primary camera with 1080p and 3264x2448 autofocus
  • Sensors
    • Compass
    • Proximity
    • Accelerometer
    • Gyro
  • Battery
    • non-removable
    • 3050 mAh Lithium-Ion
    • up to 790h (2G)/ up to 820h(3G) standby
  • Talktime
    • Up to 14h(2G)/up to 16h(3G)
  • Music
    • up to 120h
Poor battery life
The device dies faster and requires charging more often.
Automatic Fetching
By default, certain apps – such as Email, Twitter, and Facebook – fetch online data automatically, which uses more battery. Your device may be set to automatic fetching. To restrict apps from running in the background, change fetching from automatic to manual.
Unused widgets
You may have widgets that you do not use. By default, certain widgets are placed in your home screen. Each widget uses battery. The more widgets, the more battery consumption there will be. Remove any widgets you will not use.
Automatic brightness
The level of brightness of your device may not need to be changed automatically. The automatic brightness feature adjusts the brightness automatically, consuming more battery. To have a longer battery life, turn this feature off.
Unused wireless services
You may have certain services on that you may not need. Turning on services like Wi-Fi, Bluetooth, and location services requires more battery. Turn these services off when you are not using them.
High energy consumption apps
You may have high energy consumption apps running in the background that you are not using. Certain apps consume more battery than others. To check if you have one running, go to “Settings” and tap “Battery.” A lists of apps and how much battery each app uses will be displayed. Close any unused apps.
Unused apps
You may have apps running in the background. Each app uses battery. The more apps you have open, the more battery consumption there will be. To close them manually, tap the button on the bottom right and swipe them either to the left or right. To close them automatically, you can turn Stamina Mode on by going to settings, scrolling to and selecting power management. Once there, you can locate and select that option.
Battery Charged more than needed
You may be charging your phone more often than necessary. Frequently charging your phone before the 95% of the battery is used disrupts the charging and discharging flow of the capacitors in your battery. To avoid this, charge your phone only when its battery is discharged between 90% and 95%.
Faulty battery
You may have a faulty battery. To check if the battery is faulty, plug in your device. If it turns on, but does not hold charge, the battery is faulty and needs to be replaced. If you have this problem you need to replace your battery. A guide to replace the battery can be found here.
Overheating
Your phone starts to feel really warm and occasionally feels a bit unresponsive or slow.
Phone used too much or for too long
Your phone may be overused. Give your phone an hour or so of break. You can also remove the case to enable to phone to cool down.
Phone is running too many apps or processes
Make sure to turn off WiFi or Bluetooth connection when they are not in use. Disable applications that are not in use and are running in the background. Also avoid using moving wallpapers as they uses a lot the phone's operating memory.
Phone's battery is old
Your battery may be too old to operate for long periods of time. Getting new batteries may decrease significantly levels of overheating. Phone batteries should be replaced every 1-2 years. A guide to replace the battery can be found here.
LED for notifications malfunction
The notification LED isn't working properly or isn't working at all.
LED malfunction in Stamina Mode
Stamina mode disables LED notifications, so make sure to go to Settings >Power Management> turn off STAMINA mode.
LED malfunction while having ‘Back up my Data’ setting on
Backing up the phone can also cause the LEDs to not work. You can fix this by going to Settings> Backup & Reset and deselect ‘Back up my Data’ and select ‘Factory data reset.’ However, this method may cause you to lose some data.
Wi-Fi dropping/ won’t connect
There is low WiFi connectivity or sudden dropping of WiFi signal when there is a known source.
Wi-Fi won't work while in Stamina Mode
There may be a chance that the phone’s power saving mode is interfering with the WiFi connectivity. For example, Stamina Mode, cuts all connections when your device is in sleep mode. Troubleshooting and possible solutions: Make sure Bluetooth is off, as well as Stamina Mode (SETTINGS>POWER MANAGEMENT>STAMINA MODE)
Wi-Fi won't work because of a problem with router
Your device may not be responsible. It may be the router. Restart the router and phone. Then check that you have the right WiFi password and details. Turn the MAC filter off on your router and make sure you have added your phone’s MAC address. Finally, try changing the channel on your router and make sure DHCP is on
Wi-Fi won't connect to Wi-Fi without any router problems or being in Stamina Mode (Phone not up to date)
The firmware on your device may not be up to date. Make sure that you are running the latest firmware. Try Sony's PC companion for further troubleshooting.
Micro-SD not working properly
My Micro-SD card is either not read, or when it does, it displays “memory has been removed unexpectedly.”
Micro-SD card is read but isn't working
The Micro-SD card you have may not be compatible with your device. Try one from a different manufacturer.
Micro-SD card isn't being read
You purchased a Micro-SD card recommended for your device, but it is not being read by your device. Format the card on the phone itself. If it is not read by your device or computer, try SD Formatter.
Phone Camera Problems
Phone camera isn't working or the pictures are being obstructed by a broken lens or there is an obstruction in or around the lens area.
Obstructed lens by camera showing black screen or obstructed image
Check that there is nothing obstructing the lens of your phone. This could be your finger, phone cover which is not properly placed or some other object. If this is the case then remove object from blocking the lens area.
Broken lens or malfunctioning camera
If your lens is cracked or your lens or camera not working then you will need to replace the camera. A guide to replace the camera can be found here.
Non-functional Screen
The screen isn't working properly; it blacks out often and becomes unresponsive.
Unresponsive screen/ power button ( commonly known as "Sleep of death")
The device may have a glitch that cause screen failure. In order to fix this problem, a hard reset is usually required. However, Sony has released an Over the Air Update (OTA) to fix this problem.
Screen is Broken or Cracked
You will need to replace the screen with a new one. A guide to replace the screen can be found here.
Audio Problems
You hear unwanted sounds from the phone and the audio doesn't play very well either.
Audio problems while music is being streamed
You may have a problem with connectivity. If you are having issues, check if you have both Bluetooth and WiFi on at the same time, and if you do, disable one of them as they could be clashing with each other, resulting in your music not playing properly. If this doesn't work check for WiFi troubleshooting section in this page.
Audio problems while music is played from storage
Check whether this problem occurs when you play certain songs or if it happens when you play any song. If it only happens with a few songs, then the problem may be that those song files were originally corrupted. In that case, you must delete the song files from your phone. Afterward, download them back into your phone. Make sure that the songs you download play without problem on your computer. You can be sure that the files aren't corrupt if they are downloaded from a legal, credible source. If the music files still don't work, then you may have a problem with the storage of music in your device. In this case, check this page for additional information: Micro-SD not working properly section .
Faulty headphone jack
If you have this problem then you need to replace your headphone jack. A guide to replace the headphone jack can be found here .
Motherboard non-functional
The motherboard is faulty or dies so the phone won't work at all
Phone Totally Unresponsive
Check to see if battery is correctly inserted and/or charged
Check to see if phone is turned on
If all previous steps are completed, replacement of Motherboard may be necessary following this guide .
Author
with
Carlos
222 Reputation
1 Guide authored
Cal Poly, Team 4-6, Maness Fall 2015 Member of Cal Poly, Team 4-6, Maness Fall 2015
CPSU-MANESS-F15S4G6
4 Members
72 Guides authored
2 Comments
Some app opens automatically and the screen becomes non functional.Just the app on the particular place on screen opens.
Sumithbhansali - Reply Share
my sony xperia z ultra has no sound, Can't play music, videos or youtube. No sounds on alarms and games either. Everything has no sound. I open the audio setting and it says "Unfortunately, audio setting has stopped"
Indri Liszto - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 7,436
