Sony Xperia Z Ultra Motherboard Replacement
    1. Sony Xperia Z Ultra Motherboard Replacement, Battery: step 1, image 1 of 1
      • Use the small suction cup to lift the back panel:
      • Press the small suction cup on to the middle of the back panel.
      Ask FixBot
    2. Sony Xperia Z Ultra Motherboard Replacement: step 2, image 1 of 1
      • While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
      • While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
      • Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
      Ask FixBot
    3. Sony Xperia Z Ultra Motherboard Replacement: step 3, image 1 of 1
      • Remove the back panel by pulling the small suction cup upwards.
      Ask FixBot
    4. Sony Xperia Z Ultra Motherboard Replacement: step 4, image 1 of 1
      • Remove the following six screws with a Phillips #000 screwdriver:
      • five silver 2.1 mm screws
      • one gold 3.1 mm screw
      Ask FixBot
    5. Sony Xperia Z Ultra Motherboard Replacement: step 5, image 1 of 1
      • Pry the plastic motherboard shield open by placing the spudger under the shield and running it along the edges.
      Ask FixBot
    6. Sony Xperia Z Ultra Motherboard Replacement: step 6, image 1 of 1
      • Use care to remove the motherboard shield, as it may break. The motherboard shield is made of a very thin plastic.
      • Remove the motherboard shield by lifting the lower end upwards first.
      Ask FixBot
    7. Sony Xperia Z Ultra Motherboard Replacement: step 7, image 1 of 2 Sony Xperia Z Ultra Motherboard Replacement: step 7, image 2 of 2
      • Detach the battery connection cable by prying it upward with the spudger.
      Ask FixBot
    8. Sony Xperia Z Ultra Motherboard Replacement: step 8, image 1 of 1
      • Pry the upper end of the antenna upwards with the spudger.
      Ask FixBot
    9. Sony Xperia Z Ultra Motherboard Replacement: step 9, image 1 of 1
      • Detach the antenna by pulling the upper end upwards and outwards.
      Ask FixBot
    10. Sony Xperia Z Ultra Motherboard Replacement: step 10, image 1 of 1
      • Insert the spudger underneath the battery and run it back and forth to remove any adhesive.
      Ask FixBot
    11. Sony Xperia Z Ultra Motherboard Replacement: step 11, image 1 of 1
      • Remove the battery from the phone.
      Ask FixBot
    1. Sony Xperia Z Ultra Motherboard Replacement, Motherboard: step 12, image 1 of 1
      • Pry the antenna assembly upwards with the spudger.
      Ask FixBot
    2. Sony Xperia Z Ultra Motherboard Replacement: step 13, image 1 of 1
      • You should hear a slight "click" when the antenna assembly has been completely loosened.
      • Remove the antenna assembly by pulling it upwards from the right end.
      Ask FixBot
    3. Sony Xperia Z Ultra Motherboard Replacement: step 14, image 1 of 1
      • Remove the mic cover by placing the spudger underneath the cover and prying it upward.
      Ask FixBot
    4. Sony Xperia Z Ultra Motherboard Replacement: step 15, image 1 of 1
      • The metal shield is very thin, so use care to remove the metal shield as it can easily be bent.
      • Remove the metal shield cover by prying its right end upwards with the flat part of the spudger.
      Ask FixBot
    5. Sony Xperia Z Ultra Motherboard Replacement: step 16, image 1 of 1
      • Remove the mic connection from the motherboard ribbon by prying it upwards with the spudger.
      • Once released, the orange ribbon will resemble a flap.
      Ask FixBot
    6. Sony Xperia Z Ultra Motherboard Replacement: step 17, image 1 of 2 Sony Xperia Z Ultra Motherboard Replacement: step 17, image 2 of 2
      • Use care to remove the black plastic spacer, as it may bend if excessive force is used. The black plastic spacer is very thin and extremely fragile.
      • Gently pry the black plastic spacer upwards with the spudger.
      • Remove the black plastic spacer from the phone by gently pulling it upwards.
      Ask FixBot
    7. Sony Xperia Z Ultra Motherboard Replacement: step 18, image 1 of 1
      • Release the LCD digitizer connection by prying it upwards with the spudger.
      • The LCD digitizer is distinguished by a longer connection strip.
      Ask FixBot
    8. Sony Xperia Z Ultra Motherboard Replacement: step 19, image 1 of 2 Sony Xperia Z Ultra Motherboard Replacement: step 19, image 2 of 2
      • Use care to detach the vibration motor connection, as it may break if excessive pressure is applied. The vibration motor connection is tiny and fragile.
      • Use the flat part of a spudger to detach the vibration motor connection. It is a tiny white box with red and black wires leading to the motor.
      • Once the connection has been removed, slide the spudger underneath the vibration motor to release it from the adhesive.
      Ask FixBot
    9. Sony Xperia Z Ultra Motherboard Replacement: step 20, image 1 of 2 Sony Xperia Z Ultra Motherboard Replacement: step 20, image 2 of 2
      • Remove the loudspeaker connection by prying it upwards with the spudger.
      Ask FixBot
    10. Sony Xperia Z Ultra Motherboard Replacement: step 21, image 1 of 1
      • Remove the orange ribbon connection by prying it upwards with the spudger.
      Ask FixBot
    11. Sony Xperia Z Ultra Motherboard Replacement: step 22, image 1 of 2 Sony Xperia Z Ultra Motherboard Replacement: step 22, image 2 of 2
      • Pry the small black metal bracket off with the spudger.
      • Gently remove the ribbons that are attached to the side of the phone to avoid cracking them.
      • Remove the small black metal bracket by lifting it upwards and outwards.
      Ask FixBot
    12. Sony Xperia Z Ultra Motherboard Replacement: step 23, image 1 of 1
      • Detach the orange ribbon by wedging the spudger between the phone's casing and the ribbon. This will help prevent damage to the strip.
      Ask FixBot
    13. Sony Xperia Z Ultra Motherboard Replacement: step 24, image 1 of 1
      • Detach smaller orange ribbon by wedging the spudger between the phone's casing and the ribbon. This will help prevent damage to the strip.
      Ask FixBot
    14. Sony Xperia Z Ultra Motherboard Replacement: step 25, image 1 of 2 Sony Xperia Z Ultra Motherboard Replacement: step 25, image 2 of 2
      • All parts connected to the motherboard with an orange ribbon are fragile and should be treated with extreme care.
      • Pry up the connection strip at the end of the motherboard using the flat part of the spudger to free the motherboard.
      • The connection strip has adhesive underneath.
      Ask FixBot
    15. Sony Xperia Z Ultra Motherboard Replacement: step 26, image 1 of 1
      • Manually remove the copper tape anchoring the motherboard's black ribbon.
      • When removing the motherboard in its entirety, make sure all securing points have been released.
      Ask FixBot
18 other people completed this guide.
Omar Herrera
1,347 Reputation
1 Guide authored
Cal Poly, Team 4-6, Maness Fall 2015 Member of Cal Poly, Team 4-6, Maness Fall 2015
CPSU-MANESS-F15S4G6
4 Members
72 Guides authored
11 Guide Comments
Most grateful very helpful and easy to follow thank you very much
Edward - Reply Share
please help me how to solder the flex cable to the motherboard
jawadsupercool - Reply Share
very helpful. thanks.
can anyone suggest me where to buy the motherboard of sony z ultra?
neko - Reply Share
Can anyone tell me how to replace flex connected to motherboard. Sony z ultra 4g
smaran727 - Reply Share
how much this board..???
anak zalal - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 32
All Time: 10,475
