Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Sony PlayStation Classic Not Powering Up
The Playstation Classic will not power on.
Faulty Power Adapter
Ensure that correct USB cable, provided with system, is securely connected to correct port on the back of the gaming system. Connect USB port into AC adaptor (not included, must support 5 V, 1.0 A), then connect adaptor into electricity supply. Done correctly, after pressing the power button, the POWER indicator should produce a steady green light indicating the system is on.
Faulty Motherboard
If the system still does not flash a green light, the internal motherboard might be damaged due to water spillage or other unknown causes. If this is the case, the motherboard will need to be replaced.
Image Not Displaying
Although the Playstation Classic is powered on, an image won’t display on screen.
Improper Use of HDMI Cord
Be sure to check that the HDMI cord is properly inserted into the back of the Playstation Classic. Connect other output of HDMI cord into the correct port in TV system. Ensure that your TV is switched to the correct input. An image should be portrayed once the HDMI is properly secured.
Error With TV or Output System
If the image is still not shown, there may be an issue with your display system. In this case, consult guides on that specific device.
Power Button Unresponsive
The device’s power button is loose or jammed and won’t turn the system on.
Jammed Power Button
If the power button on your system is jammed, you will need to open up the console in order to have access to its internal features. A cause to the jamming of this button could be due to a worn down or jammed spring. Note: The only required tools for this process will be a small screwdriver.
Broken Power Button
If the button is dented or shattered to the point where it is no longer functional, it will need to be replaced.
Open Button Unresponsive
The Open button will not switch between games when pressed.
Jammed Open Button
Similar to the power button, if this button is jammed, it will be necessary to access the interior of the console.
Broken Open Button
There might be an issue with the internal spring which makes the button pop up and down. It could be dislodged or worn down which would cause the button to remain unfunctional. In order to evaluate this, you will have to open up the device.
If the button is noticeably cracked, the Open button must be replaced.
Controllers Are Unresponsive
The PlayStation is not responding to the controllers commands.
Micro USB is Unplugged
If your console is not responding to any of the controllers commands, it is likely due to a faulty controller cord. There is a chance that the cord became unplugged from the motherboard internally.
Faulty Controller Cord
Sony uses USB to Micro USB cords that are about 5 feet in length for the PlayStation Classic controllers. Overtime and through wear and tear, these cords can become faulty. This cord will need to be replaced by taking the controller apart, requiring a small screwdriver.
A replacement cord can be purchased through this amazon link: https://www.amazon.com/dp/B004GF8TIK/ref...
Author
with
Jake Lane
492 Reputation
3 Guides authored
Cal Poly, Team S7-G13, Paton Spring 2020 Member of Cal Poly, Team S7-G13, Paton Spring 2020
CPSU-PATON-S20S7G13
3 Members
96 Guides authored
11 Comments
I have unresponding controller, swiched controllers and niether worked; so its separated inside on the mother board. Don't think I can fix it.
Michael - Reply Share
i bought the small classic but can not see anything on the computer monitor. It is ridiculous that the ps classic only has hdmi port. I had to buy adapter hdmi to vga . All monitors here have vga only. But nothing shows on the monitor. I got laptop hdmi does not show it either. Classic crap. Worth 5 at most. Can not return to shop.
albert einstein - Reply Share
It flashing orange green when I put my game stick in
Zackory Gilman - Reply Share
So I tried both controllers it wont work and yes what type of screwdriver should I use
Jamal Saeed - Reply Share
My PlayStation Classic flashes “Red” LED lights even though it is not over heating. It happened after I tried to hack my PlayStation classic and now it doesn’t work. how do I fix this?
gamerrudy13 - Reply Share
Past 24 Hours: 7
Past 7 Days: 15
Past 30 Days: 79
All Time: 15,250
