Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Playbase Does Not Connect to Audio Device
The Playbase does not respond when playing any audio source.
The Playbase Has Not Been Set Up
If the device has not been set up yet, it will not connect to an audio device, even if it is directly plugged into the television. Setup (or re-setup) your Playbase according to this tutorial.
The Playbase Is Not Connected to the Internet
If the playbase is not connected to the internet, it cannot wirelessly connect. See The Playbase does not Connect to the Internet troubleshooting guide below, also linked on the left.
The Audio Connection Is Not Working
If the audio connection is completely non-functional, ensure the optical audio cable is securely plugged in.
Alternatively, try unplugging it and then plugging it back in.
Alternatively, try using another optical audio cable.
Alternatively, replace the optical audio port according to the Optical Audio Port Replacement guide.
The Playbase Does Not Connect to the Internet
The Playbase cannot access remote internet content.
The Playbase Has Not Been Set Up, or Is Configured Incorrectly
The Network Router Is Down
If the router is down, nothing will be able to access the internet, including the Playbase. Ensure that the internet connection functions on another device.
The Ethernet Connection Is Faulty
If the cable or external ethernet port are faulty, the Playbase will be unable to connect. Test the cable and the ethernet port with another device.
The Ethernet Port Is Faulty
If the Playbase Ethernet port is broken, it will be unable to use an ethernet connection. Try using a wireless connection.
Alternatively, replace the Ethernet port according to the Ethernet Port Replacement guide.
The Playbase Speakers Are Not Producing Sound Properly
The Playbase doesn’t sound quite right.
The EQ Settings Are Incorrect
If the EQ settings are incorrect for the content being played, the Soundbase can sound bad. Adjust the EQ settings from the Sonos app.
The TV Is Not Connected
If the TV is not plugged into the Playbase, it will not be able to receive and play audio. Plug the TV into the Playbase.
Alternatively, unplug and replug the cable on both ends if it is already plugged in.
The Wireless Network Is Disconnected
If the wireless network is not connected, the Playbase may not be able to connect to devices playing sound. Follow the troubleshooting guide for ‘’The Playbase does not connect to the internet’’
The TV Has Not Been Set Correctly
If the TV does not have the correct audio output configured, it may not be sending audio to the Playbase. Change your TV settings to output sound on the playbase.
The Audio Cable Is Faulty
If the audio cable is degraded but not completely broken, the sound quality may be poor. Make sure the optical audio cable is securely plugged in.
The Optical Audio Port Is Faulty
If all else fails, the optical audio port may be faulty. Replace the optical audio port according to the Optical Audio Port Replacement guide.
‘’Note: if you have another device that uses an optical audio cable, test the cable with that device to ensure the issue is with the optical audio port instead of the cable itself.’’
The Speakers Are Faulty
If you can identify a specific spot on the Playbase where sound quality is degraded, one of the speakers may be broken. Replace one or more of the faulty speakers using:
The Playbase’s Audio Connection Is Skipping or Lagging
The Playbase has pauses during playback, or skips portions of content.
The Internet Connection Is Insufficient
If streaming from an internet source, ensure no other devices are using large amounts of bandwidth (video streaming, audio streaming, downloading, etc.)
The Playbase Is Receiving Interference
If using many devices in close proximity to the Playbase, there may be interference. See this page for examples.
The Optical Audio Connection Is Faulty
If the optical audio connection is degraded, it may create skips and gaps. Make sure the optical audio cable is securely plugged in.
The Playbase Is Not Responding to the Remote
The Playbase does not respond when issuing commands with the remote control.
The Remote Is Too Far Away
If you are too far away from the Playbase, the remote may be out of range. Try moving closer to the Playbase.
The Remote Has Not Been Set Up
If you have a new remote or never set it up initially, the Playbase cannot read the remote. Set up your remote according to this article.
The IR Receiver Is Blocked
If the IR receiver is blocked, the Playbase cannot receive commands from the remote. Ensure there are no obstructions between the remote and the ‘’SONOS’’ label on the front.
The Remote Is Receiving Interference
If there is a nearby device such as a microwave or plasma-screen television, it may be providing interference. Ensure that there are no such devices nearby.
The Remote Is Out of Battery
If the remote is out of battery, it cannot communicate with the Playbase. Ensure the batteries in the remote have charge.
The Remote Is Faulty
If the remote is faulty, it may not be able to communicate properly with the Playbase. Replace the remote with a known good remote.
The IR Receiver Is Faulty
If the IR receiver is faulty, it may not be able to receive commands properly. Replace the IR receiver according to the IR Receiver Replacement guide.
The Playbase Does Not Power On
The Playbase does not light up, respond, or otherwise show evidence of powering on.
The Playbase Is Not Plugged In
If the Playbase is not plugged in, or the outlet used is non-functional, the Playbase cannot receive power. Ensure the Playbase is plugged into a working power outlet.
The Power Cable Is Faulty
If the power cable is degraded, the Playbase may be receiving little or no power. Replace the power cable with a known good power cable.
The Power Port Is Faulty
If the power port is broken, the Playbase may not be able to receive power. Do not attempt repair on the power port; the risk of electrical damage or injury is high.
Author
with
George Slivka
341 Reputation
3 Guides authored
Cal Poly, Team S17-G2, White Fall 2018 Member of Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Members
96 Guides authored
1 Comment
My playbase is 6 months old and does not start. 2nd time in 6 months that I send it back to repair. Not happy for a 600€ product
Nicolas C - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 37
All Time: 5,655
