Sonos Playbase IR Reciver Replacement
    1. Sonos Playbase IR Reciver Replacement, Bottom Panel: step 1, image 1 of 3 Sonos Playbase IR Reciver Replacement, Bottom Panel: step 1, image 2 of 3 Sonos Playbase IR Reciver Replacement, Bottom Panel: step 1, image 3 of 3
      Tool used on this step:
      Pro Tech Toolkit
      $79.95
      Buy
      • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
      • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
      • Melt the adhesive with an iOpener for ease of opening
      • Use a Metal Spudger if the plastic spudgers do not work.
      • Take care to avoid damaging the plastic or the device if using a metal spudger.
      Ask FixBot
    2. Sonos Playbase IR Reciver Replacement: step 2, image 1 of 2 Sonos Playbase IR Reciver Replacement: step 2, image 2 of 2
      Pro Tech Toolkit
      $79.95
      Buy
      • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
      • Remove the seven 44mm T-20 screws by turning counter-clockwise.
      • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
      • Record where each screw belongs for easier reassembly.
      Ask FixBot
    3. Sonos Playbase IR Reciver Replacement: step 3, image 1 of 2 Sonos Playbase IR Reciver Replacement: step 3, image 2 of 2
      Pro Tech Toolkit
      $79.95
      Buy
      • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
      • Use a metal spudger if plastic openers do not work.
      Ask FixBot
    1. Sonos Playbase IR Reciver Replacement, Main Speaker Array: step 4, image 1 of 2 Sonos Playbase IR Reciver Replacement, Main Speaker Array: step 4, image 2 of 2
      Ask FixBot
    2. Sonos Playbase IR Reciver Replacement: step 5, image 1 of 2 Sonos Playbase IR Reciver Replacement: step 5, image 2 of 2
      • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
      • See Recognizing & Disconnecting Cable Connectors for more information.
      Ask FixBot
    3. Sonos Playbase IR Reciver Replacement: step 6, image 1 of 3 Sonos Playbase IR Reciver Replacement: step 6, image 2 of 3 Sonos Playbase IR Reciver Replacement: step 6, image 3 of 3
      Pro Tech Toolkit
      $79.95
      Buy
      • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
      Ask FixBot
    4. Sonos Playbase IR Reciver Replacement: step 7, image 1 of 1
      • Remove the main speaker array by gripping it on both sides and pulling it out.
      • The array may require a significant amount of force to remove.
      • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
      • Do not to yank the array out too suddenly or too far as this may damage the device.
      Ask FixBot
    5. Sonos Playbase IR Reciver Replacement: step 8, image 1 of 1
      • Prop the removed main speaker array up on top of the main circuit board.
      Ask FixBot
    1. Sonos Playbase IR Reciver Replacement, IR Receiver: step 9, image 1 of 3 Sonos Playbase IR Reciver Replacement, IR Receiver: step 9, image 2 of 3 Sonos Playbase IR Reciver Replacement, IR Receiver: step 9, image 3 of 3
      Pro Tech Toolkit
      $79.95
      Buy
      • Lift the main speaker array to reveal the IR receiver underneath.
      • Remove the three 11 mm T-5 screws by turning counter-clockwise.
      Ask FixBot
    2. Sonos Playbase IR Reciver Replacement: step 10, image 1 of 3 Sonos Playbase IR Reciver Replacement: step 10, image 2 of 3 Sonos Playbase IR Reciver Replacement: step 10, image 3 of 3
      Ask FixBot
    3. Sonos Playbase IR Reciver Replacement: step 11, image 1 of 2 Sonos Playbase IR Reciver Replacement: step 11, image 2 of 2
      • Remove the IR receiver by grasping it with two fingers and pulling up.
      Ask FixBot
George Slivka
341 Reputation
3 Guides authored
Cal Poly, Team S17-G2, White Fall 2018 Member of Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Members
95 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 26
All Time: 1,769
