Sonos Playbase Ethernet Port Replacement
    1. Sonos Playbase Ethernet Port Replacement, Bottom Panel: step 1, image 1 of 3 Sonos Playbase Ethernet Port Replacement, Bottom Panel: step 1, image 2 of 3 Sonos Playbase Ethernet Port Replacement, Bottom Panel: step 1, image 3 of 3
      Tool used on this step:
      Pro Tech Toolkit
      $79.95
      Buy
      • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
      • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
      • Melt the adhesive with an iOpener for ease of opening
      • Use a Metal Spudger if the plastic spudgers do not work.
      • Take care to avoid damaging the plastic or the device if using a metal spudger.
      Ask FixBot
    2. Sonos Playbase Ethernet Port Replacement: step 2, image 1 of 2 Sonos Playbase Ethernet Port Replacement: step 2, image 2 of 2
      Pro Tech Toolkit
      $79.95
      Buy
      • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
      • Remove the seven 44mm T-20 screws by turning counter-clockwise.
      • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
      • Record where each screw belongs for easier reassembly.
      Ask FixBot
    3. Sonos Playbase Ethernet Port Replacement: step 3, image 1 of 2 Sonos Playbase Ethernet Port Replacement: step 3, image 2 of 2
      Pro Tech Toolkit
      $79.95
      Buy
      • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
      • Use a metal spudger if plastic openers do not work.
      Ask FixBot
    1. Sonos Playbase Ethernet Port Replacement, Ethernet Port: step 4, image 1 of 2 Sonos Playbase Ethernet Port Replacement, Ethernet Port: step 4, image 2 of 2
      • Unplug the Ethernet Port from the main circuit board by pinching the white clip and pulling upward.
      Ask FixBot
    2. Sonos Playbase Ethernet Port Replacement: step 5, image 1 of 2 Sonos Playbase Ethernet Port Replacement: step 5, image 2 of 2
      Pro Tech Toolkit
      $79.95
      Buy
      • Remove the two 18 mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
      Ask FixBot
    3. Sonos Playbase Ethernet Port Replacement: step 6, image 1 of 2 Sonos Playbase Ethernet Port Replacement: step 6, image 2 of 2
      • Remove the Ethernet Port from the housing by pinching from both sides and pulling it out.
      Ask FixBot
James Andrews
423 Reputation
4 Guides authored
Cal Poly, Team S17-G2, White Fall 2018 Member of Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Members
24 Guides authored
2 Guide Comments
I actually have a broken ethernet port on a playbase. Do you have any idea where I can buy a replacement port?
Thanks,
D
david paler - Reply Share
Does anyone know a replacement Lan card/network card/wifi card for the playbase? Seems they all fail due to this rather than the ethernet port, but sonos won’t offer a replacement card..
44yawns.spotter@icloud.com - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 37
All Time: 2,162
