The Seville Classics MSC10166 Tower Fan offers an innovative design contrasting from the traditional circular style making it sleek, compact, and quiet.
Fan does not turn on
The fan is unresponsive after pressing any button.
Lack of power
If the fan seems to be completely unresponsive, the first step is to make sure the fan is plugged in. Check the connection into the wall to make sure it is not loose in the socket. If the problem is not solved, try plugging the fan into another outlet.
Bad wire connections
After determining that the outlet is not the problem, the next step is to check the connections inside of the fan. You may need to connect any disconnected wires either by twisting them together or soldering. For guidance on checking connections and soldering, please refer to the following guide: Repairing the LEDs.
Bad fuse
If all of the connections are solid but the fan is still unresponsive, the next step is to check the fuse and replace it if necessary. Inspecting the fuse involves checking the resistance of the fuse using an ohmmeter as well as soldering to remove and replace it. For more help on soldering and checking the fuse, please refer to the following guide: Repairing the LEDs.
LEDs do not light up
The fan turns on and works, but there are no functioning lights.
Bad connections
Bad connections might cause the LEDs to not function. The first step to resolving this problem is to take apart the fan and check the connections of the LEDs to the circuit board. Look for any loose connections or broken wires. For instructions on fixing connections, please refer to the following guide: Repairing the LEDs.
Bad LEDs
If fixing the connections does not resolve the problem, the LEDs may have gone bad. Buy new LEDs and replace them referring to the following guide: Repairing the LEDs.
Air flow is restricted
Less air is coming out than before.
Dirty fan blades
If airflow is restricted, the fan blades may be dirty. Dust may accumulate between the fan blades and result in blockage. You may need to take off the back cover, remove the fan blades, and clean out the dust. Refer to the following guide for taking apart the fan and cleaning it out: Cleaning the Fans.
Clogged vents
Clogged vents may impair airflow. Dust may accumulate in the vents and hinder outside air from entering the fan. You may need to take off the back over and clean off the dust. Refer to the following guide for taking apart the fan and cleaning it out: Cleaning the Fans..
Buttons do not work
The buttons can be pressed but are unresponsive.
Buttons are stuck
If when you press down on a button and it does not return to it’s original position, the buttons may be dirty or covered in something sticky. In this case, take off the top cover and circuit board to clean the buttons. Refer to the following guide for cleaning the buttons: Repairing the Buttons.
Fan does not rotate
The fan works but will not turn.
Lack of lubrication
Lack of lubrication may cause the fan to not rotate. First, take time to open the fan and check if anything is blocking the fan from rotating. If there is, then remove the object. Otherwise, the problem could be the lack of lubrication. The next step is to remove the fan and lubricate the track referring to the following guide: Repairing the Rotation and Vibration of the Fan.
Blockage of track
If the fan does not rotate or stutters when rotating, there may be a blockage on the track. Take the fan apart and clean the track of all dust and other debris. Refer to the following guide for taking apart the fan and clearing blockage on the track: Repairing the Rotation and Vibration of the Fan.
Jonathon Elfar
9 Reputation
0 Guides authored
Cal Poly, Team 15-46, Forte Fall 2012 Member of Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Members
72 Guides authored
32 Comments
My fan has terrible rattling when it's on. It goes away when it's horizontal, but returns when I stand it up. It's not very old. Any ideas?
nospam - Reply Share
Help please: my problem is the fan does not turn on. I dismantle, clean, checked for loose connection and tested before putting it back together but the fan I'd not responding. It's turning on, swivel is working and lights on top are working except for the fan. Please help someone!
Zeus Custodio - Reply Share
Mine is the same. Control lights come on and it will rotate but no air. did you get a solution?
Lee - Reply Share
Mine is the same. Disappointing. Is there a solution?
Lee - Reply Share
I have same issue top light r up and green but fan not working although rotatation works.
Please provide some troubleshooting steps
zakhan42000 - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 155
All Time: 72,201
