Seville Classics MSC10166 Disassembly
Views: 13K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
155
All Time:
13,087
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
This repair guide solves any rotation and vibration problems that the fan might have. The track at the bottom of the fan is the main source of rotation and vibration problems. Use the tear-down guide to remove all other components to get to the track.
Tools
    1. Seville Classics MSC10166 Disassembly, PCB (Printed Circuit Board): step 1, image 1 of 1
      • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
      Ask FixBot
    2. Seville Classics MSC10166 Disassembly: step 2, image 1 of 1
      • Pull the front and back cover apart.
      • Be careful not to pull the front cover off completely. It holds the wires.
      Ask FixBot
    3. Seville Classics MSC10166 Disassembly: step 3, image 1 of 1
      • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
      • Shock warning: Make sure the fan is unplugged before removing the circuit board.
      Ask FixBot
    4. Seville Classics MSC10166 Disassembly: step 4, image 1 of 1
      • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
      Ask FixBot
    5. Seville Classics MSC10166 Disassembly: step 5, image 1 of 2 Seville Classics MSC10166 Disassembly: step 5, image 2 of 2
      • Remove the screws from the four corners of the circuit board.
      • Remove the circuit board from the top cover.
      • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
      Ask FixBot
    1. Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: step 6, image 1 of 2 Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: step 6, image 2 of 2
      • In order to remove the fan blade, use pliers to remove the holding nut.
      • After the holding nut is loose, use the pliers to pull up to remove the nut.
      Ask FixBot
    2. Seville Classics MSC10166 Disassembly: step 7, image 1 of 1
      • Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
      • Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
      Ask FixBot
    3. Seville Classics MSC10166 Disassembly: step 8, image 1 of 2 Seville Classics MSC10166 Disassembly: step 8, image 2 of 2
      • Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
      • Remove screws by pulling them away from the base.
      • The transformer should be free after this step.
      Ask FixBot
    1. Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: step 9, image 1 of 2 Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: step 9, image 2 of 2
      • Clean the track, removing any obstructions.
      • Lubricate the track with grease.
      Ask FixBot
2 other people completed this guide.
Queena Phung
114 Reputation
3 Guides authored
Cal Poly, Team 15-46, Forte Fall 2012 Member of Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 155
All Time: 13,087
