Cleaning the Fan Blades
Views: 12K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
135
All Time:
11,885
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
This guide will disassemble the fan to clean the fan blades.
Tools
    1. Cleaning the Fan Blades, PCB (Printed Circuit Board): step 1, image 1 of 1
      • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
      Ask FixBot
    2. Cleaning the Fan Blades: step 2, image 1 of 1
      • Pull the front and back cover apart.
      • Be careful not to pull the front cover off completely. It holds the wires.
      Ask FixBot
    3. Cleaning the Fan Blades: step 3, image 1 of 1
      • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
      • Shock warning: Make sure the fan is unplugged before removing the circuit board.
      Ask FixBot
    4. Cleaning the Fan Blades: step 4, image 1 of 1
      • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
      Ask FixBot
    5. Cleaning the Fan Blades: step 5, image 1 of 2 Cleaning the Fan Blades: step 5, image 2 of 2
      • Remove the screws from the four corners of the circuit board.
      • Remove the circuit board from the top cover.
      • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
      Ask FixBot
    1. Cleaning the Fan Blades, Fan Blades: step 6, image 1 of 1
      • Follow steps 1-4 to remove the front, back, and top covers of the fan to reach the fan blades.
      • Use a cloth to clean off dust clogged in between the fan blades.
      Ask FixBot
Vivian Fong
97 Reputation
1 Guide authored
Cal Poly, Team 15-46, Forte Fall 2012 Member of Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 135
All Time: 11,885
