Confusing Text
This wiki has grammatical errors or does not meet iFixit's writing guidelines.
For more information on the Samsung SCH-3500, head to the device page.
Phone Will Not Turn On
No matter what you do, you can't get your Samsung SCH 3500 to turn on.
Bad Battery
Perhaps the battery itself is broken and/or drained. Consider battery installation. Attempt to turn on the phone while it is charging in the wall.
Bad Logic Board
If your phone does not work while plugged into the wall via the phone charger, the problem is most likely in the logic board. It is possible that your phone needs a hard reset with a logic board installation.
Phone Shuts Off When I Unplug It
Bad Battery
The battery itself is most likely broken or dead if the phone does not operate after it is disconnected from the phone charger. Consider battery installation.
Poor Reception
Speaker is broken
If you cannot hear anyone during a call, perhaps the speakers are broken in the phone earpiece. Consider replacement.
Antenna Malfunction
Poor reception might be the effects of a malfunctioning phone antenna. If the reception is audible but not clear, antenna installation might help better hearing capabilities.
Earpiece Part is Broken
If there is a visible crack and/malfunction present in the earpiece itself, consider replacement.
Cannot Dial
Keypad Malfunction
If you find it impossible to dial numbers, the problem most likely lies with the keypad mechanism. Consider keypad installation.
My Phone is Split/Cracked
Back/Front Cover Replacement
If there is a visible crack in either the front or back covers of your phone, consider further exploration and replacement. For a crack in the back cover, consider back cover installation.
Author
with
Brett Tomashitis
36 Reputation
5 Guides authored
Clemson, Team 2-6, Benson Spring 2012 Member of Clemson, Team 2-6, Benson Spring 2012
CLEM-BENSON-S12S2G6
2 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,059
