Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Poor battery life
Your phone battery will not hold a charge very long, and dies within a few hours of being fully charged. You may be running an app that is taking up a lot of power to run, or displaying something on you phone that takes up a lot of battery life. To rectify this problem, it is a good idea to leave wifi, data, and Bluetooth off unless they are actively being used. Also, you should uninstall those applications that are taking up a lot of battery life. If this is true for most of your apps, then your battery may be too old and may need to be replaced. See battery installation guide. If replacing it doesn't work, there is one last option you can try. You can install an extended battery. The assembly will go similarly to battery installation guide.
microSD card memory full
When trying to save a file, your phone gives an "SD card memory full" error. Your memory card has too much data on it, and cannot fit any more. To fix this problem first try deleting some files you don't need from the card to free up space. If you still are getting this error, try replacing the SD card. See microSD card installation guide.
Cannot connect to your cell phone network
Your phone is unable to connect to your cellular network, and you do not have data, text, or voice service. Your SIM card may be loose. If that turns out not to be the case, it is probably faulty. See SIM card installation guide.
If you have replaced your SIM card correctly, but your cell phone still cannot connect to your cellular network, then it may be a problem with the SIM card port that you are plugging your SIM card into. If this is the case, it needs to be replaced. See SIM card port installation guide
Phone screen is obscured
You can't see clearly through the display, whether caused by dust, screen cracks, scratches, or other internal damage to the screen. Try turning the phone off and on again if the display seems scrambled. If that doesn't help, try cleaning the outside of the display with a microfiber cloth and water. If the screen is still obscured, you may need to replace it. See screen installation guide.
Author
with
Lucas Carter
190 Reputation
1 Guide authored
Cal Poly, Team 15-44, Forte Fall 2012 Member of Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,661
