Up to 20% off select tools
Samsung Droid Charge Battery Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
95
All Time:
2,522
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
Replace the battery in your Samsung Droid Charge. Remove the battery before disassembling or reassembling the device.
    1. Samsung Droid Charge Battery Replacement, Rear Cover: step 1, image 1 of 1
      • Open up the back case on the phone from the groove in the bottom of the phone.
      • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
      Ask FixBot
    1. Samsung Droid Charge Battery Replacement, Battery: step 2, image 1 of 1
      • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
      • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
      Ask FixBot
5 other people completed this guide.
Author
with
Luke Gordon
199 Reputation
5 Guides authored
Cal Poly, Team 15-44, Forte Fall 2012 Member of Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 95
All Time: 2,522
