Samsung Droid Charge SIM Card Port Replacement
    1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: step 1, image 1 of 1
      • Open up the back case on the phone from the groove in the bottom of the phone.
      • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
      Ask FixBot
    1. Samsung Droid Charge SIM Card Port Replacement, Battery: step 2, image 1 of 1
      • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
      • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
      Ask FixBot
    1. Samsung Droid Charge SIM Card Port Replacement, microSD: step 3, image 1 of 1
      • Push the SD card further into its metal slot until you hear a click.
      • Release the card, and it should automatically eject itself.
      • Remove the SD card.
      Ask FixBot
    1. Samsung Droid Charge SIM Card Port Replacement, SIM Card: step 4, image 1 of 1
      • Slide the SIM card out of its casing by pushing on it and sliding it upward.
      Ask FixBot
    1. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: step 5, image 1 of 1
      • Carefully remove the back cover.
      • Remove the two 5mm screws with a small Phillips head screwdriver.
      Ask FixBot
    2. Samsung Droid Charge SIM Card Port Replacement: step 6, image 1 of 1
      • Removal of the back half of the casing.
      • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
      • Use a prying motion to lift the casing up. This will separate the phone casing.
      • Repeat this motion all around the screen edge until the casing pops off.
      Ask FixBot
    3. Samsung Droid Charge SIM Card Port Replacement: step 7, image 1 of 1
      • Release the volume button flex cable on the right.
      • Release the pop connector on the motherboard located to the left of the SIM card port.
      Ask FixBot
    4. Samsung Droid Charge SIM Card Port Replacement: step 8, image 1 of 2 Samsung Droid Charge SIM Card Port Replacement: step 8, image 2 of 2
      • Your SIM card port is now unattached.
      • Remove SIM card port from motherboard.
      Ask FixBot
4 other people completed this guide.
Lucas Carter
190 Reputation
1 Guide authored
Cal Poly, Team 15-44, Forte Fall 2012 Member of Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 104
All Time: 3,013
