Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Bluetooth Connection Problems
The device is not connecting to the speaker
Cannot Find The Speaker On Your Device
Check to make sure the speaker is on and is within a 30 feet of your device. It is possible another device is connected; ensure all other previously connected devices have been disconnected. Restart the speaker by pressing the power button to turn it off, then again to turn it back on. Do the same with the bluetooth feature on your device. If the problem persists, reset the device by pressing the reset button and reconnect or delete the speaker from the device and research for it again.
Device Not Connecting
Check if the speaker is on and the right device name is selected. If both are correct, try rebooting the device. It is possible other devices are causing interference, shut off surrounding bluetooth devices. If the problem persists, reset the device by pressing the reset button and reconnect or delete the speaker from the device and search for it again.
Low Voice Or Distortion
Keep changing volume on device and the volume stays low
Battery May Be Low
Recharge the speaker by plugging it into the power adapter. It is recommended to use the speaker's original charging cable.
Device Problem
Low volume usually results from a change of the phone or device's settings . Check the volume settings on the device. If all volumes are turned up, try to pair with a different device to check if its a speaker issue. If the problem persists, reset the device by pressing and holding the reset button located next to the charging socket with a small pin and reconnect.
Dirt Build Up
You may need to clean the speaker from the inside. View the Omaker M4 Front Case Replacement guide for details on how to remove the front cover. Use a dry cloth and carefully wipe the cone. Use a wet wipe to clean the interior side of the front cover.
Music Breaking Off
The music constantly cuts out every minute for about a second
Connection Distance
You will realize the music will start cutting off when you separate your smart phone or device from the speaker for a distance of 9 to 10 meters . Ensure that the speaker is no more than 30 feet (9 meters) away from the source. Ensure there are no obstacles (e.g wall) between the speaker and the source.
Motherboard Connections
Wire connections of the speaker connected to the motherboard might be loose inside the device from dropping the device. In this case, follow the Omaker M4 Back Case Replacement guide to disassemble the speaker.
Blue Light Does Not light Up
The device is playing music but the light will not stay on
Battery Low
Recharge and try again after a full charge. If the problem persists, reboot the device by turning it off and on. Otherwise, you may need reset the device by holding the reset button for a couple of seconds.
Light Bulb Does Not Work
If the Bluetooth light does not light up, you might have moved the light source from the inside due to an impact or you have blocked the light path when removing the motherboard. In this case, you need to follow the Omaker M4 Motherboard Replacement guide to disassemble the speaker and put the light source back in place.
Connection Distance Getting Shorter
The connection distance is not as far as stated on the box
Battery May Be Low
Plug the speaker into the power adapter and try again after a full charge. It is recommended to use the speaker's original charging cable and make sure it is working by testing it on other devices.
Device Issue
Trying pairing with a different device. Ensure that the speaker is no more than 30 feet (9 meters) away from the source.
Interference
Ensure there are no obstacles between the speaker and the source. Obstacles reduce connectivity distance drastically. Test the Bluetooth range in an open environment without interference.
Speaker Won’t Charge
Speaker would not charge after connecting it to power adapter
Charging Cable Problem
Make sure you are using the cable that came with the device. If you are and it is still not charging, try using a similar Micro-USB cable. You can check if the cable is working by connecting it to another device with a similar charging socket.
Speaker Charging Socket
If water gets into the device, it will lead to damaging the socket port and this causes problems in the motherboard. In this case, you can remove the motherboard by following the Omaker M4 Motherboard Replacement guide and try drying it with warm air (hot air might damage the components on the motherboard) , if it is still not working or if it is not the case, then you need to replace the motherboard or buy a new speaker.
Author
with
[deleted]
679 Reputation
4 Guides authored
12 Comments
the cable is fine and will charge my phone. So " when I turn the speaker on it plays for maybe 1 min and beeps twice and goes off. it will not charge. it will not find the BT as it used to do red light stays on as it plays for the 1 min. Never been wet or out doors. it just quit holding a charge.
watergirl3 - Reply Share
Me too. This speaker just stopped working. Never dropped. Never outside. Just bought it 4 months ago. WTF?
The Sato HOUSE - Reply Share
Oh yes I have had it about 3 months and it worked fine till one day it will not hold a charge.
well I had mine one month used it 4 hours and will not charge
chris_hunt74 - Reply Share
i use mine every night because i cant go to bed without music, and my speaker wont make sound or the beeping noises to when it turns on, connects, and powers off. it will connect but it wont have sound at all and its fully charged.
megeseavey - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 45
All Time: 18,654
