Up to 20% off select tools
Omaker M4 Motherboard Replacement
Views: 2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
122
All Time:
2,039
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Removing the motherboard from the device is fairly simple. However, be careful not to remove the motherboard without removing the three screws and the wires from the speaker and microphone.
    1. Omaker M4 Motherboard Replacement, Back Case: step 1, image 1 of 1
      • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
      Ask FixBot
    2. Omaker M4 Motherboard Replacement: step 2, image 1 of 2 Omaker M4 Motherboard Replacement: step 2, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
      Ask FixBot
    3. Omaker M4 Motherboard Replacement: step 3, image 1 of 2 Omaker M4 Motherboard Replacement: step 3, image 2 of 2
      • Use a magnet to remove the screws after unscrewing them and place them aside.
      Ask FixBot
    4. Omaker M4 Motherboard Replacement: step 4, image 1 of 1
      • Carefully remove the back cover without breaking the battery wire.
      Ask FixBot
    5. Omaker M4 Motherboard Replacement: step 5, image 1 of 2 Omaker M4 Motherboard Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
      • The battery is still attached to the back cover.
      Ask FixBot
    1. Omaker M4 Motherboard Replacement, Motherboard: step 6, image 1 of 2 Omaker M4 Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Remove the mic wire by carefully pulling the plug out of the socket.
      Ask FixBot
    2. Omaker M4 Motherboard Replacement: step 7, image 1 of 1
      • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
      Ask FixBot
    3. Omaker M4 Motherboard Replacement: step 8, image 1 of 2 Omaker M4 Motherboard Replacement: step 8, image 2 of 2
      • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
      Ask FixBot
    4. Omaker M4 Motherboard Replacement: step 9, image 1 of 2 Omaker M4 Motherboard Replacement: step 9, image 2 of 2
      • Remove the screws using the screwdriver.
      • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
      Ask FixBot
    5. Omaker M4 Motherboard Replacement: step 10, image 1 of 2 Omaker M4 Motherboard Replacement: step 10, image 2 of 2
      • Carefully remove the motherboard with your hand by lifting it from the device.
      Ask FixBot
2 other people completed this guide.
Author
with
[deleted]
679 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 122
All Time: 2,039
