Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
My Nvidia Shield Pro Won’t Turn On
I pressed the power button, but the device won’t turn on or have any reaction and I can’t see anything on the big screen.
Nvidia Shield is Not Powered On
Check to see if you actually pressed the power button first, if you are still not seeing anything on the screen, check to see if your Nvidia Shield is connected to the big screen through HDMI/DisplayPort.
Nvidia Shield is Not Plugged In
Check if your power cord is plugged in for both the I/O board on the device and the outlet.
Nvidia Shield is Not Responsive
Your I/O board may be faulty and your device is not being powered on. Consider checking the replacement guide on how to replace the I/O board on the device
My Nvidia Shield Pro USB Port is Not Working
My device won’t read or recognize my USB insert.
Nvidia Shield has Dirty USB Ports
Clean both USB insert and port with preferably alcohol wipes or a clean rag.
Nvidia Shield has Damaged USB Ports
Try connecting the USB device you are trying to insert into another device to see if the problem is with the USB device. If that’s not the issue, your I/O board on the Nvidia Shield may need to be replaced.
My Nvidia Shield Pro is Making a Whirring Noise
My device makes a lot of whirring when I turn it on and use it.
Nvidia Shield Pro Accumulated a lot of Dust Inside the Device
Use a compressed air duster around the fans to get rid of the accumulated debris.
My Nvidia Shield Pro is Slow or Shuts Down Prematurely
My device shuts down minutes after I turn it on, or my device has an extremely slow reaction to my inputs.
Nvidia Shield has Damaged Fans
Your Nvidia Shield Pro may have faulty fans/heat sinks, and may need to be replaced.
Nvidia Shield is Extremely Unresponsive
Your Nvidia Shield Pro may have a faulty hard drive, check the replacement guide on how to replace your hard drive.
My Nvidia Shield Bluetooth Controller’s D-Pad No Longer Presses Down
The d-pad of my controller does not move when I press down on it.
Nvidia Shield Controller has a Dirty D-pad
Clean the D-pad and the area around it with non-alcohol wipes or a clean rag, if you want to make sure it is extra clean, use a compressed air duster to blow out any remaining particulates.
Nvidia Shield Controller has a Damaged D-pad
If the D-pad feels extremely loose even after cleaning it, try opening it up and check to see if the D-pad is broken, check the replacement guide to learn how to open up your Nvidia Shield Controller.
My Nvidia Shield Bluetooth Controller’s Thumbsticks are Moving Irregularly
Sometimes when I push my controller’s joysticks in a certain direction smoothly, the movement on the screen is irregular or “jittery”.
Nvidia Shield Controller has Dirty Thumbsticks
Clean the area around the thumbsticks with a compressed air duster. If needed, clean the face of the controller with non-alcoholic wipes to ensure that all of the controller’s cavities are clean.
Nvidia Shield Controller has Broken Thumbsticks
If the thumbsticks are behaving irregularly even after cleaning, try opening it up and check and see if your thumbsticks are broken, the thumbsticks are detachable and replaceable, check the replacement guide to learn how to open up your controller
Author
with
Jimmy Chen
753 Reputation
3 Guides authored
Cal Poly, Team S18-G2, White Winter 2020 Member of Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Members
72 Guides authored
11 Comments
nvidia shield on light always on but unit has no output
simsic - Reply Share
Nvidia Shield stuck in boot load
stanley_williams90 - Reply Share
Ethernet port burned out or doesn't work anymore. Can that be repaired or replaced?
Juan R Angel - Reply Share
Did you resolve your problem?
Chris - Reply Share
Second vote for the Ethernet port not working question … WiFi working,
Chris - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 138
All Time: 10,842
