Nvidia Shield Pro Android TV I/O Board Replacement
    1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: step 1, image 1 of 2 Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: step 1, image 2 of 2
      • Flip to the back side of your Nvidia Shield Pro Android TV.
      • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
      • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
      Ask FixBot
    1. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: step 2, image 1 of 3 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: step 2, image 2 of 3 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: step 2, image 3 of 3
      • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
      • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
      Ask FixBot
    2. Nvidia Shield Pro Android TV I/O Board Replacement: step 3, image 1 of 3 Nvidia Shield Pro Android TV I/O Board Replacement: step 3, image 2 of 3 Nvidia Shield Pro Android TV I/O Board Replacement: step 3, image 3 of 3
      • Detach the pack of wires by pulling it away from the socket.
      Ask FixBot
    3. Nvidia Shield Pro Android TV I/O Board Replacement: step 4, image 1 of 3 Nvidia Shield Pro Android TV I/O Board Replacement: step 4, image 2 of 3 Nvidia Shield Pro Android TV I/O Board Replacement: step 4, image 3 of 3
      • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
      Ask FixBot
    4. Nvidia Shield Pro Android TV I/O Board Replacement: step 5, image 1 of 2 Nvidia Shield Pro Android TV I/O Board Replacement: step 5, image 2 of 2
      • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
      Ask FixBot
    5. Nvidia Shield Pro Android TV I/O Board Replacement: step 6, image 1 of 1
      • Gently pull the hard drive out of the device.
      Ask FixBot
    1. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: step 7, image 1 of 3 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: step 7, image 2 of 3 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: step 7, image 3 of 3
      • Detach the brown side of the connector from the I/O board by pulling it upward.
      • Remove the screw from the silver plate using a T6 Torx screwdriver.
      • Put the cable aside after removing it.
      Ask FixBot
    2. Nvidia Shield Pro Android TV I/O Board Replacement: step 8, image 1 of 2 Nvidia Shield Pro Android TV I/O Board Replacement: step 8, image 2 of 2
      • Detach the small bundle of black wires from the I/O board by gently pulling upward.
      • Be very gentle because the wires are very fragile.
      Ask FixBot
    3. Nvidia Shield Pro Android TV I/O Board Replacement: step 9, image 1 of 2 Nvidia Shield Pro Android TV I/O Board Replacement: step 9, image 2 of 2
      • Remove the three T6 Torx screws from the I/O board.
      Ask FixBot
    4. Nvidia Shield Pro Android TV I/O Board Replacement: step 10, image 1 of 3 Nvidia Shield Pro Android TV I/O Board Replacement: step 10, image 2 of 3 Nvidia Shield Pro Android TV I/O Board Replacement: step 10, image 3 of 3
      • Detach the multi-colored (red/yellow/black) wire from the I/O board by pulling it away from the socket.
      Ask FixBot
    5. Nvidia Shield Pro Android TV I/O Board Replacement: step 11, image 1 of 1
      • Gently remove the I/O board by sliding it away from the exterior input/output sockets on your Nvidia Shield Pro.
      Ask FixBot
9 other people completed this guide.
Jimmy Chen
753 Reputation
3 Guides authored
Cal Poly, Team S18-G2, White Winter 2020 Member of Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Members
72 Guides authored
2 Guide Comments
Where can I buy Nvidia Shield Pro Android TV I/O Board? Greentings from Brazil.
Sergio Santos - Reply Share
Aniyone managed to get a source for this part, The IO board
Yoda Mann - Reply Share
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 139
All Time: 7,619
