Nvidia Shield Pro Android TV Fan/Heat Sink Replacement
    1. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: step 1, image 1 of 2 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: step 1, image 2 of 2
      • Flip to the back side of your Nvidia Shield Pro Android TV.
      • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
      • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
      Ask FixBot
    1. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: step 2, image 1 of 3 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: step 2, image 2 of 3 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: step 2, image 3 of 3
      • Remove the five screws with a T6 Torx screwdriver.
      • Two of the screws are located directly on top of the fan/heat sink. The other three screws are located on a small triangle plate on the left side of the fan/heat sink.
      Ask FixBot
    2. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: step 3, image 1 of 2 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: step 3, image 2 of 2
      • Once the screws are removed, gently detach the multi-colored wired connection from the motherboard.
      Ask FixBot
    3. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: step 4, image 1 of 1
      • Gently remove the fan/heat sink out of the Nvidia Shield.
      Ask FixBot
4 other people completed this guide.
Jimmy Chen
753 Reputation
3 Guides authored
Cal Poly, Team S18-G2, White Winter 2020 Member of Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Members
72 Guides authored
7 Guide Comments
Hello can you tell me where to buy the fan and the plastic case opener?
Sajid Idrees - Reply Share
From iFixit is generally the best for plastic spudgers/openers.
as for the fan apparently the Fan Model Number is BAZA0508R5U and there's plenty available on ebay and amazon.
Nic Ganglen - Reply Share
My version had screws in the back which I had to remove, and then I could simply slide it away from the ports in the back to open it. The inside was completely different as well, but it's a pretty simple device.
John Doe - Reply Share
This is the 500GB 2015 version they're showing.
Joseph Oliveira - Reply Share
I have the Shield TV Pro Model: P2897 (2019 version)-> The latest model, even though it's 7 years old as of 2/1/25.
The pictures shown here looks nothing like the model I have.
You would think that even though these instructions provide detailed information on how to replace the abnormally noisy Fan that they would include information on what MODEL they're using here, unbelievable.
Proflex.Fitness - Reply Share
Past 24 Hours: 8
Past 7 Days: 67
Past 30 Days: 305
All Time: 17,925
