Phone will not turn on
No matter what you do, the phone will not turn on.
Low battery
If the phone will not turn on, the battery may simply be drained or bad. Plug phone into an AC adapter and see if anything happens. If the phone will no longer charge, the battery must be replaced.
Disconnected battery
If plugging the phone in does not work, the battery may be disconnected. Be sure that the battery is secured into the phone. See Battery Replacement Guide.
Unresponsive power button
If the phone will not turn on, the problem could be with the power button. Try disassembling the power button. See Power Button Guide.
Unresponsive screen
If the problem lies with the screen, then the phone requires technical support for screen replacement.
Battery will not charge
The battery will not charge when hooked up to the charger.
Disconnected charger
If the battery will not charge, the problem may be that the charger is disconnected. Make sure that it is secured in both the phone and the power source.
NOTE: Be sure power source is fully functional.
If the battery will not charge, it may be disconnected. Be sure that the battery is secured and connected to the phone. See Battery Replacement Guide.
Dead battery
If the battery will not charge, it may be dead and a replacement battery will be needed.
Faulty charge port
If the battery will not charge, the problem could be that the charge port is faulty or disconnected. See Charge Port Replacement Guide.
Cannot hear through earpiece
You cannot hear through the earpiece during calls, voicemail, etc.
Low volume
If you cannot hear through the earpiece, the volume may be too low. Increase the volume using the vertical keys on the side of the phone. It may also help to make sure the volume keys are unobstructed. See Case Replacement Guide.
Poor signal strength
If you cannot hear through the earpiece, the signal strength may be poor. If indoors move near a window or go outside. If outdoors move to a different area.
Broken speaker
If you cannot hear through the earpiece, the speaker may be broken and requires technical support for speaker replacement.
Screen will not display anything
Nothing will show up on the screen.
If the screen will not display anything, the signal strength may be poor. If indoors move near a window or go outside. If outdoors move to a different area.
Loose screen connection or broken screen
If the screen will not display anything, the screen connection may be loose or it may be broken. This requires technical support for screen replacement.
Phone will not send/receive calls
The phone cannot send or receive any calls.
Low battery
If the phone will not send/receive any calls, the battery may simply be drained or bad. Plug phone into an AC adapter and see if anything happens. If the phone will no longer charge, the battery must be replaced.
If the phone will not send/receive any calls, the signal strength may be poor. If indoors move near a window or go outside. If outdoors move to a different area.
Unresponsive keypad
If the phone will not send/receive any calls, the keypad may be unresponsive.
See below.
Obstructed antenna
If the phone will not send/receive any calls, the antenna may be obstructed. Make sure that the top of the phone is not blocked by a hand or other object.
Keypad will not respond
The keypad will not respond when pressed.
Low battery
If the keypad will not respond, the battery may simply be drained or bad. Plug phone into an AC adapter and see if anything happens. If the phone will no longer charge, the battery must be replaced.
Loose/broken buttons
If the keypad will not respond, the buttons may be broken or loose. See Keypad Replacement Guide.
Sticky keys
Make sure keypad is clean and in proper position. See Keypad Replacement Guide.
Phone will not access voice mail
The phone will not access voice mail
No mail service
If the phone will not access voice mail, you may not have mail service. Call wireless provider.
Mail service not set up
If the phone will not access voice mail, the mail service may not be set up. Call wireless provider.
Voice mail number not saved in phone
If the phone will not access voice mail, the voice mail number may not be saved in the phone. Press Menu, go to Messages > Voice messages > Voice mailbox number. Enter voice mailbox number; press OK.
Saved voice mail number is incorrect
If the phone will not access voice mail, the saved voice mail number may be incorrect. Call wireless provider.
Incorrect password
If the phone will not access voice mail, the password may be incorrect. Call wireless provider.
Receiver cannot hear broadcasted voice
The person receiving your call cannot hear your voice.
Blocked microphone
If the receiver cannot hear your voice, the microphone may be blocked. Make sure that nothing is obstructing the microphone.
Loose/broken microphone
If the receiver cannot hear your voice, the microphone may be loose or broken and the phone requires technical support for microphone replacement.
Phone is getting poor reception
Calls may be crackling or silent.
If the phone is getting poor reception, the signal strength may be poor. If indoors move near a window or go outside. If outdoors move to a different area.
Obstructed antenna
If the phone is getting poor reception, the antenna may be obstructed. Make sure the top of the phone is not blocked.
Phone casing is cracked
There are cracks in the phone case.
Cracked phone case
If the phone casing is cracked, see Case Replacement Guide.
Cannot access memory card
Can't get to the memory card.
SIM card is unresponsive
If you cannot access the memory card, the SIM card may be unresponsive. See SIM Card Installation Guide.
Motherboard is bad
Unresolved problems continue to occur.
If problems persist, see Circuit Board Replacement Guide.
Author
with
Clinton
57 Reputation
7 Guides authored
Clemson, Team 14-5, Benson Fall 2012 Member of Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 Members
96 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 958
