Up to 20% off select tools
Nokia 8390 Power Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
89
All Time:
956
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 3 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide shows you how to access the power button in case or needed replacement.
    1. Nokia 8390 Power Button Replacement, Back Cover: step 1, image 1 of 1
      • Locate the button on the bottom of the back cover.
      Ask FixBot
    2. Nokia 8390 Power Button Replacement: step 2, image 1 of 3 Nokia 8390 Power Button Replacement: step 2, image 2 of 3 Nokia 8390 Power Button Replacement: step 2, image 3 of 3
      • Depress the button with your finger.
      • While the button is depressed, slide the back cover off of the phone.
      Ask FixBot
    1. Nokia 8390 Power Button Replacement, Outer Case: step 3, image 1 of 3 Nokia 8390 Power Button Replacement, Outer Case: step 3, image 2 of 3 Nokia 8390 Power Button Replacement, Outer Case: step 3, image 3 of 3
      • Grasp the top and bottom of the front cover.
      • Grasp the phone body with your other hand.
      • Lightly pull the casing off of the phone.
      Ask FixBot
    1. Nokia 8390 Power Button Replacement, Power Button: step 4, image 1 of 3 Nokia 8390 Power Button Replacement, Power Button: step 4, image 2 of 3 Nokia 8390 Power Button Replacement, Power Button: step 4, image 3 of 3
      • The casing should be separated into two parts now.
      • Locate the power button at the very top of the front casing.
      Ask FixBot
    2. Nokia 8390 Power Button Replacement: step 5, image 1 of 3 Nokia 8390 Power Button Replacement: step 5, image 2 of 3 Nokia 8390 Power Button Replacement: step 5, image 3 of 3
      • Use the spudger to push the power button through the casing.
      Ask FixBot
Author
with
Keith
41 Reputation
1 Guide authored
Clemson, Team 14-5, Benson Fall 2012 Member of Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 89
All Time: 956
