Phone won't turn on
Low battery
  • Check the battery meter. Charge the phone if necessary.
Drained/bad battery
  • If the phone turns on but powers down as soon as the charger is removed the battery is drained/bad and needs to be replaced. See Battery Replacement Guide.
Battery is improperly installed
Damaged motherboard
  • If a new battery has been installed and the phone still does not power on, the motherboard may be damaged. See Replace Circuit Board Guide.
Battery won't hold a charge
Charging cable is loose
  • Verify that the charger is firmly inserted.
Drained/bad battery
Phone turns on but the screen is still dark
LCD screen is disconnected/improperly connected
Damaged LCD screen
  • If the LCD screen is properly connected but still not functioning, the screen may need to be replaced. See Replace LCD Guide.
Cracked/damaged screen cover
Unresponsive keys
Keypad cover is damaged/improperly installed
Keypad sensor is damaged/improperly installed
Voice is not being transmitted through the phone
In an area of poor reception
  • Go to an area of better reception.
Antenna is damaged/improperly installed
Microphone is damaged/improperly installed
Damaged motherboard
Author
with
Carson Meena
16 Reputation
5 Guides authored
Clemson, Team 14-2, Benson Fall 2012 Member of Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Members
144 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 895
