Motorola i710 LCD Screen Replacement
    1. Motorola i710 LCD Screen Replacement, Battery Cover: step 1, image 1 of 2 Motorola i710 LCD Screen Replacement, Battery Cover: step 1, image 2 of 2
      • Slide the cover release button towards the bottom of the phone
      • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
      Ask FixBot
    1. Motorola i710 LCD Screen Replacement, Battery: step 2, image 1 of 1
      • Push the battery towards the top of the phone and lift up.
      Ask FixBot
    1. Motorola i710 LCD Screen Replacement, LCD Screen Cover: step 3, image 1 of 3 Motorola i710 LCD Screen Replacement, LCD Screen Cover: step 3, image 2 of 3 Motorola i710 LCD Screen Replacement, LCD Screen Cover: step 3, image 3 of 3
      • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
      • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
      • The four screws holding the upper half of the phone together should now be visible.
      Ask FixBot
    2. Motorola i710 LCD Screen Replacement: step 4, image 1 of 2 Motorola i710 LCD Screen Replacement: step 4, image 2 of 2
      • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
      • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
      Ask FixBot
    3. Motorola i710 LCD Screen Replacement: step 5, image 1 of 3 Motorola i710 LCD Screen Replacement: step 5, image 2 of 3 Motorola i710 LCD Screen Replacement: step 5, image 3 of 3
      • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
      • The LCD screen should now be completely separated from the phone.
      Ask FixBot
    1. Motorola i710 LCD Screen Replacement, LCD Screen: step 6, image 1 of 3 Motorola i710 LCD Screen Replacement, LCD Screen: step 6, image 2 of 3 Motorola i710 LCD Screen Replacement, LCD Screen: step 6, image 3 of 3
      • Use a spudger to detach the ribbon cable connecting the the LCD screen to the rest of the phone.
      • The TFT LCD screen will now lift out from the phone casing.
      • Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
      Ask FixBot
Carson Meena
16 Reputation
5 Guides authored
Clemson, Team 14-2, Benson Fall 2012 Member of Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Members
143 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 799
