Up to 20% off select tools
Motorola i710 Keypad Sensor Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
3
Past 30 Days:
18
All Time:
738
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
Once the back cover, battery, and motherboard have been removed, the keypad can accessed.
    1. Motorola i710 Keypad Sensor Replacement, Battery Cover: step 1, image 1 of 2 Motorola i710 Keypad Sensor Replacement, Battery Cover: step 1, image 2 of 2
      • Slide the cover release button towards the bottom of the phone
      • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
      Ask FixBot
    1. Motorola i710 Keypad Sensor Replacement, Battery: step 2, image 1 of 1
      • Push the battery towards the top of the phone and lift up.
      Ask FixBot
    1. Motorola i710 Keypad Sensor Replacement, Motherboard: step 3, image 1 of 3 Motorola i710 Keypad Sensor Replacement, Motherboard: step 3, image 2 of 3 Motorola i710 Keypad Sensor Replacement, Motherboard: step 3, image 3 of 3
      • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
      • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
      • The motherboard should now be completely disconnected from the phone.
      Ask FixBot
    1. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: step 4, image 1 of 2 Motorola i710 Keypad Sensor Replacement, Keypad Sensor: step 4, image 2 of 2
      • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
      • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
      Ask FixBot
Author
with
Katelyn
1 Reputation
2 Guides authored
Clemson, Team 14-2, Benson Fall 2012 Member of Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 738
