Up to 20% off select tools
Motorola i710 Microphone Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
19
All Time:
749
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Once the back cover has been removed, the microphone can be accessed as shown in this guide.
    1. Motorola i710 Microphone Replacement, Battery Cover: step 1, image 1 of 2 Motorola i710 Microphone Replacement, Battery Cover: step 1, image 2 of 2
      • Slide the cover release button towards the bottom of the phone
      • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
      Ask FixBot
    1. Motorola i710 Microphone Replacement, Battery: step 2, image 1 of 1
      • Push the battery towards the top of the phone and lift up.
      Ask FixBot
    1. Motorola i710 Microphone Replacement, Back Casing: step 3, image 1 of 3 Motorola i710 Microphone Replacement, Back Casing: step 3, image 2 of 3 Motorola i710 Microphone Replacement, Back Casing: step 3, image 3 of 3
      • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
      • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
      Ask FixBot
    1. Motorola i710 Microphone Replacement, Microphone: step 4, image 1 of 3 Motorola i710 Microphone Replacement, Microphone: step 4, image 2 of 3 Motorola i710 Microphone Replacement, Microphone: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Lift the circuit board away from the case of the phone, being careful not to break the wire that goes up into the hinge. This will give you access to the microphone.
      • The microphone sits just below the keys on the front cover molding.
      • Grasp the microphone with tweezers and lift it out of the front cover.
      Ask FixBot
Author
with
Carson Meena
16 Reputation
5 Guides authored
Clemson, Team 14-2, Benson Fall 2012 Member of Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 749
