Motorola 120c Will Not Turn On
You can’t get your phone to turn on.
Battery Has Been Drained
The battery could have run out of charge. Try plugging the phone in to the charger and turning it on again.
Battery Needs Replacing
The battery itself could be malfunctioning. If plugging the phone into the charger has no effect, the battery may need to be replaced. A guide for replacing the battery can be found here.
Display Needs Replacing
The display could be broken if you are sure the phone is on and you still don't see anything. It may need to be replaced. A guide to replacing the display can be found here.
Motherboard Needs Replacing
The motherboard could be damaged and may need replacing. A guide to replacing the motherboard can be found here.
Phone Experiencing Sound Issues
You can’t hear calls, ringtones, or button sounds.
Phone Volume is Off
Check to make sure the phone is not on mute or vibrate.
Setting for Button Sounds is Off
Check the phone settings to see if the keypad sounds are turned off.
Phone Experiencing Microphone Issues
People cannot hear you speaking during calls.
Call Volume is on Mute
Check to make sure that the microphone volume is not muted.
Broken Microphone
The microphone could be broken if the microphone volume is not muted. It may need to be replaced. A guide to replacing the microphone can be found here.
Keypad Buttons Not Responding
Your phone is not responding to button presses.
Keypad needs Replacing
The keypad could be damaged and may need replacing. A guide to replacing the motherboard can be found here.
Motherboard needs Replacing
Author
with
Eric Dazet
352 Reputation
5 Guides authored
Cal Poly, Team 6-21, Amido Spring 2012 Member of Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Members
108 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 29
All Time: 952
