Up to 20% off select tools
Motorola 120c Keypad Replacement
Views: 1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
18
All Time:
1,020
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 4 - 5 minutes
Difficulty: Very easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This process involves first removing the battery, outer case, and motherboard. After, the keypad can be easily removed.
    1. Motorola 120c Keypad Replacement, Battery: step 1, image 1 of 2 Motorola 120c Keypad Replacement, Battery: step 1, image 2 of 2
      • Hold the phone and pull the back latch down towards the bottom.
      • Remove the back panel by releasing the latch and lifting from the top.
      Ask FixBot
    2. Motorola 120c Keypad Replacement: step 2, image 1 of 3 Motorola 120c Keypad Replacement: step 2, image 2 of 3 Motorola 120c Keypad Replacement: step 2, image 3 of 3
      • Remove the battery by pushing the bottom end towards the top, then lifting up.
      Ask FixBot
    1. Motorola 120c Keypad Replacement, Motherboard: step 3, image 1 of 3 Motorola 120c Keypad Replacement, Motherboard: step 3, image 2 of 3 Motorola 120c Keypad Replacement, Motherboard: step 3, image 3 of 3
      • Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
      • Once the screws are removed, simply lift the back panel off
      Ask FixBot
    2. Motorola 120c Keypad Replacement: step 4, image 1 of 3 Motorola 120c Keypad Replacement: step 4, image 2 of 3 Motorola 120c Keypad Replacement: step 4, image 3 of 3
      • Remove the motherboard by lifting it up and out.
      Ask FixBot
    1. Motorola 120c Keypad Replacement, Keypad: step 5, image 1 of 3 Motorola 120c Keypad Replacement, Keypad: step 5, image 2 of 3 Motorola 120c Keypad Replacement, Keypad: step 5, image 3 of 3
      • Peel the keypad from the front case.
      • The keypad may be stuck either to the logic board, below the screen, or the phone case itself.
      Ask FixBot
Author
with
Mitchell Nesheim
26 Reputation
1 Guide authored
Cal Poly, Team 6-21, Amido Spring 2012 Member of Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 1,020
