Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓This process involves first removing the battery, outer case, and motherboard. After, the display can be removed from the motherboard.
Hold the phone and pull the back latch down towards the bottom.
Remove the back panel by releasing the latch and lifting from the top.
Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
Once the screws are removed, simply lift the back panel off
Tool used on this step:Tweezers$4.99
Use tweezers to pry off the four clasps that hold the display in place.
