Motorola 120c Motherboard Replacement
  1. Motorola 120c Motherboard Replacement, Battery: step 1, image 1 of 2 Motorola 120c Motherboard Replacement, Battery: step 1, image 2 of 2
    • Hold the phone and pull the back latch down towards the bottom.
    • Remove the back panel by releasing the latch and lifting from the top.
    Ask FixBot
  2. Motorola 120c Motherboard Replacement: step 2, image 1 of 3 Motorola 120c Motherboard Replacement: step 2, image 2 of 3 Motorola 120c Motherboard Replacement: step 2, image 3 of 3
    • Remove the battery by pushing the bottom end towards the top, then lifting up.
    Ask FixBot
  3. Motorola 120c Motherboard Replacement, Motherboard: step 3, image 1 of 3 Motorola 120c Motherboard Replacement, Motherboard: step 3, image 2 of 3 Motorola 120c Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
    • Once the screws are removed, simply lift the back panel off
    Ask FixBot
  4. Motorola 120c Motherboard Replacement: step 4, image 1 of 3 Motorola 120c Motherboard Replacement: step 4, image 2 of 3 Motorola 120c Motherboard Replacement: step 4, image 3 of 3
    • Remove the motherboard by lifting it up and out.
    Ask FixBot
Leonel Arjon
11 Reputation
1 Guide authored
Cal Poly, Team 6-21, Amido Spring 2012 Member of Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Members
26 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 1,038
